vco
- 48
- 15
How is the transient vibration of a piston engine usually simulated?
I know that in order to define the vibration loading you need the mass properties and dimensions of the moving components plus the cylinder pressure curve. And of course you need to know the firing order, V-angle (if applicable), etc.
However, since this is a transient case you would in fact need a set of cylinder pressure curves for different engine speeds and throttle positions, right? Depending on the chosen resolution for the engine speed and throttle position that sounds as quite a lot of data to be measured. Are there any industry practices where you utilize clever interpolation and thus avoid having to obtain such a vast number of cylinder pressure curves?
I am not especially experienced regarding engines, but I am very familiar with vibration analysis in general.
