Transistors: Collector vs Emitter (where does the symmetry get broken)
In summary: The asymmetry in geometry is due to the fact that the emitter and collector are not symmetrical. The asymmetry in doping is due to the fact that the emitter is heavily doped while the collector is lightly doped.
aeftimia
I thought I had a good understanding of transistors, but I have seen articles on how to tell the collector from the emitter. I had always pictured transistors as a perfectly symmetrical device. Either side could be the collector, and the opposite side was the emitter. Clearly, there is some subtlety I am missing.
So what physically makes the collector and emitter distinct?
iThey is no way it is symetrical. Collector is very lightly doped and emitter is heavily doped. That's the reason collector base junction can take a larger reverse voltage. You can make the device work like a transistor if you reverse the C and E, but it don't not work very well.
If it was perfectly symmetrical, both active and reverse bias regions would be identical.
Collector is very lightly doped because, after reverse biasing the base-collector, you can "collect" charge carries over that very large depletion region.
Remember: lighter doping, wider depletion region.
The lighter doping (and hence wider depletion region on the collector side of the CB junction) is, as yungman said, to increase the reverse breakdown voltage of the CB junction.
Even low power general purpose BJT's are usually designed for a CB reverse bias voltage of around 30 too 40 volts, with higher voltage devices requiring several hundred volts or more. Remember that under normal forward bias (active region) operation the CB junction is in fact reverse biased. If the same doping was used on the collector as was used on the emitter, most transistors would be unable to operate at much more than about 4 to 5 volts (Vce).
For the emitter, the higher levels of doping are used to increase the injection efficiency. For example, in an npn transistor, the heavy n+ doping in the emitter causes the vast majority of current across the BE junction to be electrons emitted from the n side (the emitter) rather than holes emitted from the base. Any holes emitted from the base are just "wasted" current, contributing to base current but contributing nothing collector current, and hence greatly reducing current gain.
It's helpful to look at the cross section of an actual BJT like in the image below:
http://www.allaboutcircuits.com/vol_3/chpt_2/8.html#03302.png
As you can see there are asymmetries in both the geometry and the doping.
Related to Transistors: Collector vs Emitter (where does the symmetry get broken)
What is the purpose of a transistor?
A transistor is a semiconductor device that is used to amplify and switch electronic signals. It consists of three layers of a semiconductor material, with each layer having a different level of conductivity.
What is the difference between the collector and the emitter in a transistor?
The collector is the region of a transistor that collects the majority carriers (electrons or holes) flowing through the transistor. It is usually doped to have a higher level of conductivity compared to the base. On the other hand, the emitter is the region that emits the majority carriers into the circuit. It is usually doped to have a higher level of conductivity compared to the collector.
Why is there a difference in conductivity between the collector and the emitter?
The difference in conductivity between the collector and the emitter is intentional and necessary for the proper functioning of the transistor. This difference is created during the manufacturing process by doping the different regions of the transistor with specific impurity atoms. This asymmetry allows the transistor to amplify and switch electronic signals.
How does the symmetry get broken in a transistor?
The symmetry between the collector and emitter is broken by the difference in doping levels and the physical structure of the transistor. The collector is typically larger in size compared to the emitter, and it is also doped with a higher concentration of impurities. This creates an imbalance in the majority carrier concentration, resulting in a flow of electrons or holes from the emitter to the collector.
What happens if the symmetry between the collector and emitter is not broken?
If the symmetry between the collector and emitter is not broken, the transistor would not be able to amplify or switch electronic signals. The flow of majority carriers from the emitter to the collector is essential for the transistor to function as an amplifier or a switch. Without this asymmetry, the transistor would behave more like a diode, where there is no amplification or switching of signals.
  • Electrical Engineering
31K
32K
  • Mechanical Engineering
