Transition probability from two states
In summary, The problem asks about a transition from 1 to 2. The first order term from perturbation theory gives the first term in the expansion of sin^2 Ut/h, which is more sensible. So the approximation is valid for a time interval ##t## such that ##P^{(1)}(t) = P_{1 \rightarrow 2} + P_{1 \rightarrow 1} = 1## holds.
CAF123
88
A system has two independent states ##|1\rangle## and ##|2\rangle## represented by column matrices ##|1\rangle \rightarrow (1,0)## and ##|2\rangle \rightarrow (0.1)##. With respect to these two states, the Hamiltonian has a time independent matrix representation $$\begin{pmatrix} E&U\\U&E \end{pmatrix},$$ E and U both real. Show that the probability of a transition from state ##|1\rangle## to state ##|2\rangle## in a time interval ##t## is given by (without any approximation) ##p(t) = \sin^2(Ut/\hbar)##
[/B]
Time dependent Schrodinger equation
[/B]
Reexpress the states in terms of energy eigenstates, so can write the general evolution of an arbritary state. The eigenvectors of the Hamiltonian are ##\frac{1}{\sqrt{2}}(1,1) = |u_1\rangle## and ##\frac{1}{\sqrt{2}}(1,-1) = |u_2\rangle##. Then ##|1\rangle = \frac{1}{\sqrt{2}}(|u_1\rangle + |u_2 \rangle )## while ##|2\rangle = \frac{1}{\sqrt{2}}(|u_1\rangle - |u_2 \rangle ).## So generic state is $$|\Psi,t_o \rangle = C_1 (1,0) + C_2 (0,1) \Rightarrow |\Psi, t\rangle = \frac{C_1}{\sqrt{2}} (|u_1\rangle e^{-iE_1 t/\hbar} + |u_2 \rangle e^{-iE_2 t/\hbar} ) + \frac{C_2}{\sqrt{2}} (|u_1\rangle e^{-iE_1 t/\hbar} - |u_2 \rangle e^{-iE_2 t/\hbar}).$$ But I am not sure how to progress. I am looking to compute ##\langle \Psi, t | 1 \rangle## and from that extract the probability of finding state |2>.
Thanks!
You don't need to write a generic state. The problem asks about a transition from 1 to 2.
All you need to do is write (as you have already done) 1 and 2 in the eigenvector basis. Then evolve 1 in time t and project it into 2, to find the probability of finding 2.
Hi assed,
Thanks, I see. I noticed that the result obtained from the first order time dependent theory gives exactly the same result. So the first order correction to the transition probability induced by the given time independent hamiltonian is exact. Is there any reason why we would expect this or does this imply that the approximation is true regardless of size of U? Thanks!
Woops, ignore my last reply, the first order term coming from perturbation theory gives the first term in the expansion of sin^2 Ut/h, which is more sensible. So the approximation is valid for a time interval ##t## such that ##P^{(1)}(t) = P_{1 \rightarrow 2} + P_{1 \rightarrow 1} = 1## holds. Is that correct?
Related to Transition probability from two states
1. What is a transition probability from two states?
A transition probability from two states refers to the likelihood or chance of an object or system transitioning from one state to another. It is a measure of the probability of observing a specific change or transformation between two distinct states in a given system.
2. How is transition probability from two states calculated?
Transition probability from two states is calculated by dividing the number of times a particular transition occurs by the total number of possible transitions. This can be represented mathematically as P(A→B) = N(A→B)/N(total), where P(A→B) is the transition probability, N(A→B) is the number of times the transition occurs, and N(total) is the total number of possible transitions.
3. What is the significance of transition probability from two states in science?
Transition probability from two states is significant in science as it allows for the prediction and understanding of how a system or object will behave over time. It is a fundamental concept in fields such as physics, chemistry, biology, and engineering, and can be used to model and analyze a wide range of phenomena.
4. Can transition probability from two states change over time?
Yes, transition probability from two states can change over time. This is because it is influenced by various factors such as external forces, environmental conditions, and internal interactions within the system. As these factors change, the likelihood of a transition from one state to another may also change.
5. How can transition probability from two states be experimentally determined?
Transition probability from two states can be experimentally determined by conducting repeated trials and recording the number of times a transition occurs. By dividing this number by the total number of trials, an estimate of the transition probability can be obtained. This process can be repeated with different initial conditions or parameters to observe how they affect the transition probability.
