Translate into mathematical form
In summary: In this case, we know that 2x+1=y for Case 1 so we can use that to fill in two of the blanks:$2 \cdot x + 1 = \_ \cdot y+\_$Next, we know that y < x for Case 2, so we can fill in the blanks with a fraction that is less than 1, since we need to make the smaller side bigger:$2 \cdot x + 1 = \frac{\_}{\_} \cdot y+\_$We can fill in the first blank with any number, and the second blank must be greater
bergausstein
191
if the greater of two numbers is one more than twice the smaller and the smaller is x, what is the bigger? if the bigger is x, what is the smaller number?
my answer to the first part is 2x+1.
but i don't know how to represent the second condition in a mathematical form.
and can you also give me the meaning of this phrase "there are twice as many x as there are y." or at least give an equivalent interpretation of it.
thanks.
Mathematics news on Phys.org
For the second condition, let the smaller number by $y$, and so we have:
\(\displaystyle 2y+1=x\)
Now solve for $y$ to find the smaller number $y$ in terms of the larger number $x$.
the smaller number is $\frac{x-1}{2}$.
what about my second question
"there are twice as many x as y" can you give an equivalent statement for this.
How do you have to change $y$ so that the result is equal to $x$?
2x=y? i this correct?
and oh, going back to the first question why did you change $x$ to $y$ in $2x+1$?
No, that's not correct. If there are twice as many $x$ as $y$, then we have to double $y$ to be equal to $x$.
I'm not sure what you mean...I didn't change $x$ to $y$. I let $y$ be the smaller number. We have to double that smaller number, and then add 1 and this is equal to the larger number, hence:
Solving this for $y$ will give you the smaller number in terms of the larger.
my understanding to this phrase"there are twice as many x as y" is for every one $y$ there's two $x$. that's why i think about $2x=y$ as the mathematical form of it.
Suppose you have twice as many apples as oranges. If $x$ is the number of apples and $y$ is the number of oranges, how many oranges do you need so that you have an equal number of each?
i'll double the number of oranges?
Correct, you need to add the number of oranges already there so that the number of oranges and apples is the same:
\(\displaystyle x=y+y=2y\)
This means $x$ is twice is big as $y$, or "there are twice as many $x$ as there are $y$."
hmm. if i let $y=\,number \,oranges$ then $2y = number, \,of\, apples$.
or if i let $y = \,number \,of \,apples$ then $\frac{y}{2}=\,number \,oranges$
are these correct?
are these correct?
Yes, that's correct.
I was uncomfortable reading this phrase because x is used to denote two different things: a category of objects ("apples") and the number of objects of this category (number of apples). I would pose the problem as follows. "There twice as many A's as B's. Let x be the number of A's and y be the number of B's. How are x and y related?"
It's important to note that there are equations here to find and they are not together a system of equations. It's more like Case 1 and Case 2.
Case 1: $x<y$
$2x+1=y$
The bigger, $y$ is one more than twice the smaller, $x$.
Case 2: $y<x$
______________________________?
Setting up this kind of equation was always a challenge for the high school student's I tutored for standardized tests in the past. The best way I was able to relate this was to first set up something like this:
$\_ \cdot x + \_=\_ \cdot y+\_$
There are four possible blanks to try to even out the equation. If we know one side is bigger than the other then we have to make the smaller side bigger somehow.
Case 1: $x<y$
$2x+1=y$
Case 2: $y<x$
thanks for the reply jameson. but in my book I'm restricted to just use one variable. how will i do that without using another variable?
i kind of understand the first case. but I'm having a hard time with this "$\_ \cdot x + \_=\_ \cdot y+\_$ what do you mean?
I realize it might be unclear where I'm going with that so I'll use addition as an example. Let's say we're given a statement - "John is 5 years older than Frank". How can we express this mathematically? I would start by choosing two letters to represent each of their ages and do the following:
$J+\_=F+\_$.
I know that the above is not true since they are not the same age so I need to even them out. I've tried to draw two blank spaces on both sides where 5 could possibly go. It will go in one of the blanks, but which one? Lots of people will add 5 to the wrong side here.
Which one is true?
1) $J+5=F$
2) $J=F+5$
This is an easy example but the idea is important and will help with lots of word problems where you need to form equations correctly before you can solve them.
Anyway, about your question. What equation do you get if $y<x$?
Ok I think I see what you mean by using one variable. We can write everything in terms of $x$ for each case. I feel I have derailed this thread slightly so here's my solution for others to check.
Case 1: $x<y$
$2x+1=y$ so the smaller number is $x$ and the bigger number is $2x+1$.
Case 2: $x>y$
$2y+1=x$ so the smaller number is $\dfrac{x-1}{2}$ and the bigger number is $x$.
FAQ: Translate into mathematical form
What does it mean to "translate into mathematical form"?
Translating into mathematical form means expressing a real-world problem or situation using mathematical symbols, equations, and variables in order to solve it.
Why is it important to translate problems into mathematical form?
Translating problems into mathematical form allows us to use the power of mathematics to analyze and solve complex problems in a systematic and precise manner. It also helps us to communicate and share our findings with others in a universal language.
What are some common strategies for translating problems into mathematical form?
Some common strategies for translating problems into mathematical form include identifying relevant quantities and variables, writing equations to represent relationships, and using diagrams or tables to organize information.
Can any problem be translated into mathematical form?
While many real-world problems can be translated into mathematical form, there are some situations that may not be easily quantifiable or may require more complex mathematical concepts. However, approaching a problem with a mathematical mindset can often lead to new insights and potential solutions.
How can I improve my skills in translating problems into mathematical form?
The best way to improve your skills in translating problems into mathematical form is to practice. Start by breaking down complex problems into smaller, more manageable parts and identifying key variables and relationships. You can also seek out resources such as textbooks, online tutorials, and practice problems to further develop your skills.
