Translational and Rotational energy in rigid bodies
In summary, the conversation discusses the total kinetic energy of a rigid body, specifically a flat disk rotating about a single arbitrary axis through the center of mass. The participants consider the translational and rotational kinetic energy, and come to the conclusion that the total kinetic energy is equal to the sum of these two energies. However, further calculations using integrals show that there is an extra term that is actually zero, leading to a discrepancy in the total kinetic energy. The conversation ends with a request for clarification and guidance on the topic.
Zamorak
Suppose I have some sort of rigid body, a solid sphere let's say. For simplicity's sake let's assume that the sphere can only rotate about a single arbitrary axis through the center of mass. If the center of mass of the sphere is traveling with a constant velocity (with respect to some arbitrary reference frame) and the sphere also has a non-zero constant angular velocity about a single axis, will the total kinetic energy of the sphere be equal to the sum of the Rotational and Translational kinetic energy? Intuitively, I feel like the answer should be yes, but when I try to verify my intuition, the math seems to suggest otherwise.
Etotal =1/2 ∑miv2i
In the reference frame of the center of mass, the velocity of any particle is defined by its angular velocity and the distance from center of mass.
v'i = rw(cosΘ)ey - rw(sinΘ)ex
If the center of mass if moving with velocity v with respect to the reference frame we are observing the sphere at then we can apply a simple Galilean transformation to find an expression for vi
v = aey + bex
vi = (rw(cosΘ) + a)ey + (b - rw(sinΘ))ex
v2i = (v'i)2 + v2 +2v'i ⋅v
If I plug this back into the expression for the total kinetic energy, I get something odd.
Etotal = 1/2∑mi(v'i)2 + 1/2∑miv2 + ∑miv'i ⋅v
Etotal = Erotational + Etranslational + ∑miv'i ⋅v
I'm not sure if I didn't properly define translational and rotational energy in this case, but the above equation seems to imply that the total kinetic energy is more than the sum of the translational and rotational kinetic energy. I'm a little confused about mechanics concerned rotation right now, so any guidance would be greatly appreciated.
EDIT: Change "sphere" to flat disk, I wanted to work in 2 dimensions for simplicity's sake
At first, you should not that(using standard spherical coordinates and taking the centre of mass to be at the centre of the sphere) for a particle at [itex] (r,\theta,\varphi) [/itex], [itex] v_i'=r\omega \sin\theta(\cos\varphi \hat x+\sin\varphi \hat y) [/itex].
The next point is, those sums should be replaced by integrals for actual calculations because we're dealing with a continuum here. But as you can see, you have, in [itex] v_i' [/itex], sine and cosine of [itex] \varphi [/itex] which gives zero when integrated from [itex] 0 \ to \ 2\pi [/itex]. So that extra term is actually zero.
Ah, my bad, I should have specified a flat disk instead of a sphere, but I get your point. The reason I didn't start with integral in the first place was to show that there was that I didn't intend to calculate the energies, but now that you mention it if I consider the extra term as an integral it does work out.
∑miv'i⋅v
= ∑r(w)(acosΘ - bsinΘ)mi
dm = krdΘdr
∑miv'i⋅v
Integrate from 0 to R and 0 to 2π
=wk∫∫r2(acosθ - bsinΘ)dΘdr
=wk∫r2(b - b)dr
=0
I'm honestly not too familiar with using integrals in these situations, but if that's right then everything makes sense, thanks for the reply.
Related to Translational and Rotational energy in rigid bodies
1. What is translational energy in a rigid body?
Translational energy in a rigid body refers to the energy associated with the movement of the entire object in a straight line. This energy is dependent on the mass of the object and its velocity.
2. How is rotational energy different from translational energy?
Rotational energy in a rigid body refers to the energy associated with the rotation of the object around a fixed axis. Unlike translational energy, which depends on the object's linear velocity, rotational energy depends on the object's angular velocity and moment of inertia.
3. How is translational energy calculated in a rigid body?
Translational energy in a rigid body can be calculated using the formula E = 1/2mv^2, where m is the mass of the object and v is its linear velocity.
4. What is the relationship between translational and rotational energy in a rigid body?
In a rigid body, translational and rotational energy are both forms of kinetic energy and are interdependent. In other words, as the object's translational energy increases, its rotational energy also increases, and vice versa.
5. How is translational and rotational energy conserved in a rigid body?
In a closed system, the total energy, including both translational and rotational energy, is conserved. This means that the sum of the object's translational and rotational energy before and after any change or movement will remain constant.
