Translational Motion and Center of Mass
In summary, the flatcar will travel 75m in the time it takes for the worker to walk from one end to the other.
The_Fritz
A 280-kg flatcar 25m long is moving with a speed of 6.0m/s along horizontal frictionless rails. A 95-kg worker starts walking from one end of the car to the other in the direction of motion, with speed 2.0m/s with respect to the car. In the time it takes for him to reach the other end,how far has the flatcar moved?
Falls under the category of Center of Mass and Translational Motion
Ma_cm = [tex]\Sigma[/tex]F_ext
Since the rails are frictionless I figured the mass of both the flatcar and the worker are irrelevant.
Time it takes worker to walk to end of flatcar = (25m)(second/2.0m) = 12.5 s
Distance flatcar travels in the time it takes worker to walk to the other end =
(6.0m/s)(12.5s)=75m
Is this the correct answer or am I missing something? Input will be very much appreciated.
Hello! Your solution is correct. The key equation you used, Ma_cm = \SigmaF_ext, relates the mass of an object to its acceleration when all external forces acting on it are considered. In this case, since there are no external forces acting on the flatcar and worker system, the mass of the flatcar and worker are indeed irrelevant. The solution you provided correctly considers the time it takes for the worker to walk to the other end of the flatcar and the distance the flatcar travels in that time. Keep up the good work!
Your approach is correct. The distance traveled by the flatcar is equal to the distance the worker walks in the time it takes him to reach the other end, since both are moving at the same speed in the same direction. Therefore, the flatcar moves 75m while the worker walks 25m. This assumes that the worker's speed relative to the car remains constant throughout the walk.
FAQ: Translational Motion and Center of Mass
1. What is translational motion?
Translational motion is the movement of an object from one point to another in a straight line, without any rotation or change in shape.
2. What is center of mass?
The center of mass is the point at which an object's mass is evenly distributed, and where the object will balance perfectly. It is often referred to as the "center of gravity".
3. How is center of mass calculated?
The center of mass can be calculated by finding the average position of all the individual masses that make up an object. This can be done by multiplying the mass of each component by its distance from a reference point, and then dividing the sum of these products by the total mass of the object.
4. What is the importance of center of mass in physics?
The center of mass is important in physics because it is used to describe the motion of an object, and can help determine the stability and balance of an object. It is also a key concept in understanding rotational motion and collisions.
5. How does translational motion affect the center of mass?
In translational motion, the center of mass of an object will move in a straight line at a constant velocity, as all points on the object move the same distance in the same direction. However, if there are external forces acting on the object, the center of mass may accelerate in the direction of the net force.
11K
