Can Infrared Radiation Detect Extra Glossy or Thick Pages in Scanning Machines?
  • Thread starter dmehling
  • Tags
    Paper
In summary, the conversation discusses the development of a mechanism for automatically scanning documents, involving the use of a light beam and a sensor to determine if an extra page has been picked up. The question of how this would work for thick or glossy paper is raised, and the suggestion of using infrared radiation is proposed as it is less affected by optical brightening agents. It is also suggested that a self-adjusting system would be necessary to handle different types of paper and changes in the light source and detector.
dmehling
114
I am trying to develop a mechanism for automatically scanning documents which involves picking up pages or sheets of paper. I need a method for determining whether an extra page has been picked up. I have considered using a beam of light that would pass through the page or pages and a sensor on the other side of of the page could determine how much light has passed through. Less light passing through would indicate that the machine has picked up an extra page. What I am wondering is how would this work for very thick or glossy paper like the kind in a magazine? Would visible light be absorbed completely by the paper, and if so what other forms of energy could pass through such paper? Would infrared radiation be a possibility?
Infrared might be better because it will have less effect on any optical brightening agents present on the paper. And will be less sensitive to any dye printing.
You will probably have to make some sort of self adjusting system where it constantly measures a running average of the transmission of the paper being used and responds to peaks in this rather than try and determine a fixed transmission value for all paper - which will vary with type. This will also handle both changes in the light source / detector.
Of course you will have a problem if you have a sheet of high gloss paper in the middle of a stack of newsprint.
Using a beam of light and a sensor to determine the thickness of paper is a common method used in document scanning machines. However, when it comes to glossy or thick paper, visible light may not be the best option as it can be easily absorbed or reflected by the glossy surface. In this case, using infrared radiation could be a possible solution.
Infrared radiation has a longer wavelength compared to visible light, making it less likely to be absorbed or reflected by glossy or thick paper. This means that the sensor on the other side of the paper would be able to detect the infrared radiation passing through, even if the paper is glossy or thick. However, it is important to note that the amount of infrared radiation passing through the paper may still vary depending on the thickness and glossiness of the paper.
Another option to consider could be using ultrasonic waves. These waves can pass through solid objects and are commonly used in industrial and medical applications for detecting thickness and density of materials. However, implementing this technology in a document scanning machine may be more complex and costly compared to using infrared radiation.
In conclusion, while using a beam of light and a sensor is a viable option for detecting an extra page in most cases, it may not be the most effective solution for glossy or thick paper. Considering alternatives such as infrared radiation or ultrasonic waves could provide more accurate results in these situations. It would be best to conduct further research and testing to determine the most suitable method for your specific application.
FAQ: Can Infrared Radiation Detect Extra Glossy or Thick Pages in Scanning Machines?
What is the translucency of glossy paper?
The translucency of glossy paper refers to the amount of light that can pass through the paper, making it partially see-through. This is affected by the paper's thickness, coating, and opacity.
How is the translucency of glossy paper measured?
The translucency of glossy paper is measured by using a device called a specular gloss meter, which measures the amount of light reflected off the surface of the paper. The higher the gloss reading, the more light is reflected and the less translucent the paper is.
Why is the translucency of glossy paper important?
The translucency of glossy paper is important for various reasons. It can affect the appearance of printed images and text, as well as the overall quality of the paper. It can also impact the readability and legibility of printed materials.
What factors can affect the translucency of glossy paper?
The translucency of glossy paper can be affected by several factors, including the type and quality of the paper, the coating or finish used, and the thickness of the paper. Environmental factors such as humidity and temperature can also play a role.
How can the translucency of glossy paper be improved?
The translucency of glossy paper can be improved by using a higher quality paper with a thicker coating or finish. Adjusting printing settings, such as ink density, can also help improve the translucency. In some cases, using a matte finish instead of a glossy one may be more effective in reducing translucency.
