Transmission by pure scatterer layer
In summary, the conversation discusses the application of Beer's law in different scenarios, specifically in the presence of scattering. It is mentioned that in a pure absorber, the layers transmit a decreasing amount of light with increasing thickness, while in a pure scatterer, the transmission decreases harmonically. However, the mathematical calculations presented in the conversation are simplified and do not take into account real scattering processes. In order to accurately model the system, factors such as the thickness of the layers, the optical properties of each layer, and the size and concentration of particles must be considered. Overall, the conversation emphasizes the importance of defining the system and using effective medium theories to accurately calculate the effective refractive index.
snorkack
2,190
477
Beer´s law does not apply if there is any scattering.
In a pure absorber, if 1 layer absorbs 50 % of incident light and scatters 0 % then 2 consecutive layers transmit 25 % of light and absorb 75 %. And so on exponentially. 9 layers of pure absorbers would transmit 0,195% and absorb 99,8 %.
But say that there is a pure scatterer layer which reflects 50 % of incident light back to the direction it came from.
Then, assuming that 2 such layers consecutively are followed by darkness where transmitted light escapes or is absorbed, that double layer would transmit 33,3 % of incident light. 25% would be transmitted directly - but 6,25 % would be transmitted after double scattering (50 % reaches second layer, 25 % is reflected back to first layer, 12,5 % is reflected back forward to second layer, so 6,25% passes through second layer on second try), 1,5625% would be transmitted after quadruple scattering, etc. totalling 33,33%. And 66,666% would be reflected.
Likewise, from 9 layers of pure scatterer, 0,195% would pass straight through - but 9,8% would be transmitted after various numbers of scatterings.
At the limit of infinite optical depth, there would be no transmission - but unlike the case with absorber, in a scatterer the transmission at large optical depth undergoes harmonic decrease, not exponential decrease.
But my mathematic above was simplified. I counted discrete scatterers, and only transmission or reflection straight back.
Now imagine real scattering, in absence of any absorption. Like Rayleigh scattering, which can happen to any direction - light would be free to be scattered sideways till it is again Rayleigh scattered down again or back up.
Does the qualitative conclusion hold - that in absence of absorption, scattering causes only harmonic decrease of transmission and, in the limit of infinite depth, complete reflection?
Science news on Phys.org
Hi,
You need to define better your system before going to the appropriate model. First of all, the thickness of the layers matters. If it is comparable to the wavelength of the light traveling in them you would have a sort of 1D photonic crystal. If it is much larger, then it is just reflection. If the layers are much thinner you have a metamaterial, i .e. a material which is homogeneous to light, but having a graded refractive index. Then it is important to know the optical properties of each layer, particularly their complex refractive index. If what you call "the scattering layer" contains particles smaller than the wavelength of your radiation in this medium, then an effective refractive index can be calculated. If the particles are larger, you will have an intermediate layer which is actually a 3D photonic crystal, and this would greatly complicate the problem since in this case your entire system becomes a 3D photonic crystal. Any configuration different from a simple stack of homogeneous dielectric layers is quite difficult to treat analytically and then numerical simulations become very useful.
Alkim said:
Hi,
No defined layers - the layers would be arbitrary divisions of single thick layer.
Particles far smaller than wavelength - Rayleigh scattering limit. And no absorption.
The scattering direction does not matter - components perpendicular to the incoming light do not change the distribution of light intensity in the relevant dimension (assuming your material is homogeneous in perpendicular to the incoming light). Light would perform a random walk in your material.
I would expect that the fraction of transmitted light is given by ##\frac{1}{1+d/d_0}## where d is the thickness of your material and d0 is some material constant.
In such case, the layer containing the particles can be considered to be homogeneous and one can calculate an effective refractive index using some of the numerous effective medium theories. You still need to know the particle concentration (or filing factor) and size, refractive index of the particles and refractive index of the suspending medium. Also you need to know the thickness of each layer, since this is crucial for the properties of the stack. You might want to read about dielectric mirrors.
Related to Transmission by pure scatterer layer
1. What is transmission by pure scatterer layer?
Transmission by pure scatterer layer refers to the process of light or other electromagnetic waves passing through a medium that is composed of small particles that scatter the light in all directions. This phenomenon is responsible for the color of the sky and the appearance of fog and mist.
2. How does transmission by pure scatterer layer occur?
Transmission by pure scatterer layer occurs when light or other electromagnetic waves encounter small particles in a medium, such as air or water. These particles scatter the light in all directions, causing some of it to be transmitted through the medium.
3. What factors affect transmission by pure scatterer layer?
The factors that affect transmission by pure scatterer layer include the size and composition of the scattering particles, the wavelength of the incident light, and the concentration of the particles in the medium. Other factors such as temperature and pressure may also play a role.
4. How does transmission by pure scatterer layer impact visibility?
Transmission by pure scatterer layer can greatly impact visibility, as it can cause light to be scattered in all directions, making objects appear less distinct or even invisible. This is why fog, mist, and other atmospheric phenomena can make it difficult to see objects clearly.
5. What are some real-world applications of transmission by pure scatterer layer?
Transmission by pure scatterer layer has several real-world applications, including in the production of holograms and diffraction gratings, as well as in atmospheric science where it is used to study the properties of air and other gases. It also plays a role in the appearance of natural phenomena, such as the blue color of the sky and the red color of sunsets.
  • Electromagnetism
  • Astronomy and Astrophysics
  • Chemistry
