Transmission coefficient in a barrier penetration.
The discussion focuses on calculating the transmission coefficient (T) for an electron encountering a rectangular energy barrier. The user initially applied the formula T = e^(-2GL) and calculated G using the mass, barrier height, and energy values. However, the result of T = 7.18E-4 was deemed incorrect due to unit inconsistencies between energy in eV and mass/length in SI units. It was noted that the reduced Planck's constant value used was also slightly off. The conversation emphasizes the importance of ensuring all units are compatible for accurate calculations.
simon8502
An electron having total energy E=4.46 eV approaches a rectangular energy barrier with U=5.02 eV and L=949 pm. Calculate this probability, which is the transmission coefficient.
I thought this would be an easy one, given that
T=e-2GL
and
G=\sqrt{\frac{2m(U-E)}{H}} where H is the reduced Planck's constant
I just plugged in the numbers,
U=5.02eV
E=4.46eV
L=949E-12m
m=9.109E-31kg
I found that T=7.18E-4, which is apparently wrong. Can anyone point out where I went wrong?
PS. oops I just realized that I should've put this in the homework help section. First time posting. Sorry!
Did you account for the units? Your energies are in eV, while your mass and length are in SI units. There are some factors to take into account so that the quantity GL is properly dimensionless.
Found that that the hbar value I used was wrong by a few decimals. Thanks for the help :)
