Transmission line and infinite reflection coefficient
In summary, an infinite reflection coefficient can be caused by a transmission line with a purely reactive characteristic impedance.
Boorglar
210
Hello,
I am taking some microwave engineering courses and was trying to explain the concept of reflection coefficients to my friend, but he asked me a question I am unable to answer...
So we know that given a transmission line with characteristic impedance [itex]Z_0[/itex] terminated with a load impedance [itex]Z_L[/itex], the voltage reflected is related to the incident voltage by the reflection coefficient, [itex]\Gamma_L = \frac{Z_L - Z_0}{Z_L + Z_0}[/itex].
Now what happens if we pick [itex]Z_L + Z_0 = 0[/itex]? This could happen if both [itex]Z_L[/itex] and [itex]Z_0[/itex] are purely imaginary, and one is the negative of the other (maybe some inductive and some capacitive reactances cancelling each other). Normally in our courses we considered [itex]Z_0[/itex] being a real number, usually 50 ohms. But if I assume it to be complex, then the reflection coefficient can become larger than 1, and even infinite like in that case.
So what's the physical meaning of an infinite reflection coefficient / reflection coefficient larger than 1? That seems to contradict conservation of power, because you get more power reflected than input power...
So what's the physical meaning of an infinite reflection coefficient / reflection coefficient larger than 1? That seems to contradict conservation of power, because you get more power reflected than input power...[/QUOTE]
The load is storing more energy than the generator is supplying each cycle. It is similar to a series resonant circuit, where application of very small power can produce large voltages across L and C, each of them storing a large amount of energy.
Notice that a transmission line with a purely reactive characteristic impedance is a rare beast indeed.
A little thought would go a long way before making an assertion like this. A pure imaginary impedance is not a transmission line. Look at the characteristic impedance [tex]Z_0=\sqrt{\frac{R+j\omega L}{G+j\omega C}}[/tex]There is no way to make this purely imaginary.
That is not clear to me. There is currently research into advanced metamaterials with odd electrical characteristics.
However such a material would need to provide energy to the line, which can be done.
There's no free lunch, but sometimes we can steal a bit from nature.
(Of course there will always be some small real parasitics since nothing is perfect.)
FAQ: Transmission line and infinite reflection coefficient
1. What is a transmission line?
A transmission line is a specialized cable or other structure designed to carry high frequency electrical signals with minimal loss from one point to another. It is commonly used in telecommunications, radio frequency systems, and high-speed data transfer.
2. How is the reflection coefficient defined for a transmission line?
The reflection coefficient is a measure of the amount of signal reflected back from a discontinuity in a transmission line, compared to the amount of signal sent into the line. It is represented as a complex number and can be calculated using the impedance of the line and the impedance of the discontinuity.
3. What is an infinite reflection coefficient?
An infinite reflection coefficient occurs when there is an open circuit or complete break in a transmission line. In this case, all of the signal is reflected back and none is transmitted forward, resulting in an infinite reflection coefficient.
4. What factors affect the reflection coefficient of a transmission line?
The reflection coefficient of a transmission line is affected by factors such as the impedance of the line, the impedance of any discontinuities, and the frequency of the signal being transmitted. Additionally, the type and quality of the materials used in the line can also impact the reflection coefficient.
5. How can the reflection coefficient be minimized in a transmission line?
To minimize the reflection coefficient in a transmission line, it is important to match the impedance of the line to the impedance of the source and load. This can be achieved by using impedance matching techniques such as adding termination resistors or using specialized connectors. Additionally, using high-quality materials and properly designing the layout of the line can also help to reduce reflection.
