Transmission Line Model (TLM) End Resistance (Re)
In summary, contact resistance (Rc) and transfer resistance (Re) are two important parameters in characterizing the contact resistance of a transmission line model. Re is the resistance that blocks current from dispersing from the contact to the next (unloaded) contact, while Lt is the transfer length that represents the distance over which the current spreads out from the contact. The ratio of Rc/Re is important for understanding how the current density is distributed between these two resistances.
Azaxa
Hi guys.
I'm looking into the modelling of a transmission line model (TLM) and feel that I'm understanding it fairly well. Although, one parameter keeps popping up with very little explanation as to what it actually is.
It seems that to characterize contact resistance for a e.g. GaAs TLM with AuGe ohmic contacts, that the contact resistance cannot just be characterized by the sheet resistance beneath the contact (Rsk) and the semiconductor resistance (Rsh) when these two are not equal. Many resources direct me towards Re in this case.
Now, the measurement of Re appears simple, with current flowing between two contacts the voltage is measured from the end contact and a neighbouring unloaded contact, contacts 2 and 3, and this value is divided by the current between contacts 1 and 2 (fig. 6.10).
It can be characterized as:
where
Rsk = Sheet resistance beneath ohmic contact,
W = width of the contact,
d = length of the contact,
Lt = transfer length (the length from the front of the contact to where the current is 1/e*io beneath the contact).
My question is:
-Is Re the resistance from Lt to the end of the contact?
-Is Re the resistance blocking current from dispersing from the contact to the next (unloaded) contact?
P.S. the reason I believe this is because if this is the case then and increase in Lt would reduce the area from Lt to end of the contact (x=d) whereas the beginning of the contact (x=0) will have a larger area, contributing to a decrease in contact resistance (Rc) but the "leftover" current after x=Lt will be more dense due to the decrease in area at the contact end. Of course, with greater with this will reduce the resistance of both Rc and Re and finally 1/sinh(d/Lt) or sech(d/Lt) shows that there's an exponential decrease in resistance due to the ratio that current density is shared (Rc/Re = cosh(d/Lt)).
I hope this helps with explanations.
Thanks, in advance.
Hi there,
Thank you for your post and for sharing your thoughts on the measurement of contact resistance in a transmission line model. I can understand why this parameter may be causing some confusion for you.
To answer your questions, Re is not the resistance from Lt to the end of the contact. Instead, it is the resistance that blocks current from dispersing from the contact to the next (unloaded) contact. This resistance is also known as the transfer resistance.
The transfer length (Lt) is the length from the front of the contact to where the current is 1/e*io beneath the contact. It represents the distance over which the current spreads out from the contact and is affected by both the width and length of the contact.
As you mentioned, an increase in Lt would reduce the area from Lt to the end of the contact (x=d). This results in a decrease in contact resistance (Rc) because the current density is more concentrated in this smaller area. However, the decrease in area at the contact end also leads to an increase in transfer resistance (Re) because the current has a longer distance to travel before reaching the next contact.
The ratio of Rc/Re is important because it shows how the current density is distributed between the contact resistance and transfer resistance. As you mentioned, the formula 1/sinh(d/Lt) or sech(d/Lt) shows that there is an exponential decrease in resistance due to this ratio.
I hope this helps to clarify the concept of contact resistance and transfer resistance in a transmission line model. If you have any further questions, please don't hesitate to ask. Keep up the good work with your research!
FAQ: Transmission Line Model (TLM) End Resistance (Re)
What is the Transmission Line Model (TLM) End Resistance (Re)?
The Transmission Line Model (TLM) End Resistance (Re) is a parameter used in the analysis of transmission lines, which are used to transmit signals and power from one point to another. It represents the resistance of the load at the end of the transmission line, and is an important factor in determining the efficiency and performance of the line.
How is the End Resistance (Re) calculated in the TLM model?
The End Resistance (Re) in the TLM model is calculated by taking into account the resistance of the load (Rload), the characteristic impedance of the transmission line (Z0), and the length of the line (l). The formula for calculating Re is Re = Rload + (Z0/2) * (1 - e^(-2l/Z0)), where e is the base of the natural logarithm.
Why is the End Resistance (Re) important in the TLM model?
The End Resistance (Re) is important in the TLM model because it affects the reflection coefficient and standing wave ratio on the transmission line. A higher Re value can lead to higher levels of reflection and standing waves, which can result in signal distortion and power loss.
How does the End Resistance (Re) affect the efficiency of a transmission line?
The End Resistance (Re) can significantly affect the efficiency of a transmission line. A lower Re value leads to lower levels of reflection and standing waves, which can result in better signal transmission and less power loss. On the other hand, a higher Re value can reduce the efficiency of the line and cause signal degradation.
What are some common methods for minimizing the End Resistance (Re) in a transmission line?
There are a few methods for minimizing the End Resistance (Re) in a transmission line. One approach is to match the characteristic impedance of the line to the load impedance, which can minimize reflections and standing waves. Another method is to use impedance-matching networks, such as baluns or stubs, to adjust the impedance at the end of the line. Additionally, using high-quality materials for the transmission line and load can also help reduce the End Resistance (Re).
