Transmission Line Model (TLM) End Resistance (Re)
In summary: Your Name]In summary, the conversation discusses the characterization of contact resistance in transmission line models (TLMs). Re, or the end resistance, plays a crucial role in determining overall contact resistance. It represents the resistance from the transfer length (Lt) to the end of the contact and is affected by both the width and length of the contact. The ratio of current density between Rc and Re is also important, with a higher ratio resulting in a lower overall contact resistance. Optimizing both Rc and Re is key in minimizing contact resistance in TLMs.
Azaxa
Hi guys.
I'm looking into the modelling of a transmission line model (TLM) and feel that I'm understanding it fairly well. Although, one parameter keeps popping up with very little explanation as to what it actually is.
It seems that to characterize contact resistance for a e.g. GaAs TLM with AuGe ohmic contacts, that the contact resistance cannot just be characterized by the sheet resistance beneath the contact (Rsk) and the semiconductor resistance (Rsh) when these two are not equal. Many resources direct me towards Re in this case.
Now, the measurement of Re appears simple, with current flowing between two contacts the voltage is measured from the end contact and a neighbouring unloaded contact, contacts 2 and 3, and this value is divided by the current between contacts 1 and 2 (fig. 6.10).
It can be characterized as:
where
Rsk = Sheet resistance beneath ohmic contact,
W = width of the contact,
d = length of the contact,
Lt = transfer length (the length from the front of the contact to where the current is 1/e*io beneath the contact).
My question is:
-Is Re the resistance from Lt to the end of the contact?
-Is Re the resistance blocking current from dispersing from the contact to the next (unloaded) contact?
P.S. the reason I believe this is because if this is the case then and increase in Lt would reduce the area from Lt to end of the contact (x=d) whereas the beginning of the contact (x=0) will have a larger area, contributing to a decrease in contact resistance (Rc) but the "leftover" current after x=Lt will be more dense due to the decrease in area at the contact end. Of course, with greater with this will reduce the resistance of both Rc and Re and finally 1/sinh(d/Lt) or sech(d/Lt) shows that there's an exponential decrease in resistance due to the ratio that current density is shared (Rc/Re = cosh(d/Lt)).
I hope this helps with explanations.
Thanks, in advance.
Hi there,
Thank you for your question about contact resistance in transmission line models. You are correct in your understanding that Re is the resistance from the transfer length (Lt) to the end of the contact. This is also known as the "end resistance" and it represents the resistance that current encounters as it flows from the contact to the next (unloaded) contact.
The transfer length (Lt) is an important parameter in characterizing contact resistance because it represents the length at which the current begins to spread out from the contact. As you mentioned, an increase in Lt would result in a decrease in contact resistance due to a decrease in the area from Lt to the end of the contact. This is because the current is able to spread out more, reducing the density and therefore the resistance.
Additionally, the ratio of current density between the contact resistance (Rc) and the end resistance (Re) is also important in determining the overall contact resistance. As you pointed out, the ratio can be described by 1/sinh(d/Lt) or sech(d/Lt), which shows an exponential decrease in resistance as the ratio increases. This highlights the importance of optimizing both the contact resistance and the end resistance in order to minimize overall contact resistance in a TLM.
I hope this helps to clarify the role of Re in characterizing contact resistance in TLMs. If you have any further questions, please don't hesitate to ask.
FAQ: Transmission Line Model (TLM) End Resistance (Re)
What is the purpose of the Transmission Line Model (TLM) End Resistance (Re)?
The TLM End Resistance (Re) is used to model the losses at the end of a transmission line. It represents the resistance of the termination at the end of the line and helps to accurately simulate the behavior of the transmission line.
How is the TLM End Resistance (Re) calculated?
The TLM End Resistance (Re) can be calculated using the formula Re = (Z0 - ZL)/(Z0 + ZL), where Z0 is the characteristic impedance of the transmission line and ZL is the load impedance at the end of the line.
What factors affect the value of the TLM End Resistance (Re)?
The value of the TLM End Resistance (Re) is affected by the characteristic impedance of the transmission line, the load impedance, the length of the line, and the frequency of the signal being transmitted.
How does the TLM End Resistance (Re) impact the performance of a transmission line?
The TLM End Resistance (Re) can cause signal reflections and losses at the end of the transmission line, which can degrade the overall performance of the line. It is important to properly calculate and adjust the Re value to minimize these effects.
Can the TLM End Resistance (Re) be adjusted or controlled?
Yes, the TLM End Resistance (Re) can be adjusted by changing the load impedance or by adding termination components, such as resistors or capacitors, at the end of the line. This can help improve the performance of the transmission line and reduce signal reflections.
