Transmitting Torque: Meaning & Why Not Power?
  • Thread starter ZdMh
  • Tags
    Torque
In summary: Sometimes the word 'transmitted' is used for forces, but in a looser sense. For instance if you take 10 light springs, join them end-to-end vertically, and suspend a mass at the lower end, then the tension in the lower spring equals the tension in the top spring. We might say, colloquially, that...the tension in the lower spring has been transmitted to the top spring.In summary, when we talk about a torque being transmitted to a pump, this means that a force is applied to the pump and the pump is able to move due to the force.
ZdMh
When we talk about for ex. a driver rotates a pump, we say "a torque is transmitted to the pump". What does exactly this mean "Transmitting torque"? and why we said Transmitting torque and not transmitting power for ex.?
power = torque * angular_velocity
Likes ZdMh and etotheipi
I assume they would like to mention that some power of rotation is transmitted to another power of rotation with combined rolls or gears in mind.
ZdMh said:
Summary:: Why we say "Transmitting torque"? not something else?
Six of one, half dozen of the other. Depends if you are thinking about a socket wrench or a drive shaft.
Likes sophiecentaur
I'm thinking of a drive shaft in this case. But I didn't get exactly what you meant...
Welcome, ZdMh :cool:
I don't know the exact answer to your question.
The use of that word is more common for mechanisms that have rotating parts, such as gears, shafts, pulleys, flywheels and sprockets.
In most cases, torque is transferred between rotating parts via shafts to which they are solidly linked by keys or splines.
Perhaps it is associated to vehicle's transmission, which includes gear box, shafts, torque converter and differential and which function is to transfer torque from the engine to the rear wheels.
When we combine the concepts of transmitting torque and the rotational speed of parts, we arrive to the concept of transmission of power.
For other mechanisms, such as linkages, linear actuators, hydraulic cylinders, etc., the word is also used for transferring of forces from one part to another, but it is less common.
Then, we have the generation and transmission of electric power through interconnected nets.
If produced in a power plant, we again have the case of transmitting torque and the rotational speed of steam turbines and generators.
Likes berkeman, ZdMh and Delta2
Maybe it's because English is not my mother tongue, but I have problems to understand what "transmitting torque" should mean. I also couldn't make sense when you'd say a "force is transmitted to a body". A torque or force is applied and what's transmitted is angular momentum or momentum, as described by the equations
$$\dot{\vec{p}}=\vec{F}, \quad \dot{\vec{J}}=\vec{\tau}.$$
Likes weirdoguy and etotheipi
Do you mean the word "exert"?
Likes vanhees71
If the body (e.g. a drive shaft) is rotating at a uniform rate and if one is applying a torque at one end then one can harvest an identical torque at the other end. One might reasonably say that the torque has been "transmitted".
The same could be said about power.
Likes russ_watters, ZdMh and etotheipi
Thanks guys for your time to explain the idea, I truly appreciate!
I didn't get what you mean by that?
Likes Lnewqban
Well, in German I would not say "eine Kraft wurde übertragen" (which I'd translate to "a force is transmitted"), I'd say "Impuls wurde übertragen" ("momentum is transmitted"). "Eine Kraft wird angewandt/ausgeübt" ("a force is applied/exerted".
In general I think you cannot transmit "entities of intensity" ("Intensitätsgrößen") but only "entities of quantity" ("Quantitätsgrößen"). See the very instructive preface to Sommerfeld's Lectures on Theoretical Physics vol. III.
I think you are right in the broader context of flux and transport phenomena, that the momentum is that which crosses (is transmitted across) the surface but, the force only describes the rate of flow.
Sometimes the word 'transmitted' is used for forces, but in a looser sense. For instance if you take 10 light springs, join them end-to-end vertically, and suspend a mass at the lower end, then the tension in the lower spring equals the tension in the top spring. We might say, colloquially, that the spring arrangement "transmits" a force equal to the weight of the suspended mass, to my hand.
Likes Lnewqban
Well, terminology in everyday language and unfortunately also slang among scientists is not always of the precision desirable for expressing science!
Likes etotheipi
Differntiating between force/torque transmission and power transmission allows for more precision.
Likes sophiecentaur
But for instance if some charge flows through a resistor, then we would say there is a current through a surface in the resistor, but it is the charge that is transmitted through that surface. Likewise we might speak of power through a surface within the resistor, but it is energy that is being transmitted.
I think it is still imprecise to speak of transmitting a torque, for instance, since all you are really saying is that there is a torque on one end that equals numerically another torque at the other end. Same for power.
Likes vanhees71
etotheipi said:
I think it is still imprecise to speak of transmitting a torque ...Same for power.
Doesn't change the fact that both is used, and doesn't help the OP to understand the usage.
Likes etotheipi
Okay, sorry. In any case it is instructive to differentiate between torque as a means of transmitting angular momentum to a system as opposed to its colloquial usage as a numerical equality of two different torques in an equilibrium case.
Likes vanhees71 and Lnewqban
transmission of the torque
Likes Lnewqban and etotheipi
There's no better way than what we just have achieved! There are both expressions used and there's one that needs to be refined to get a full understanding.
Likes etotheipi
A.T. said:
Differentiating between force/torque transmission and power transmission allows for more precision.
Yes- its necessary in practice.
If we were discussing Electrical Power Distribution, we would mainly be interested in the Power and in the operating Voltage. Although it's the Power / Energy that we'd be paying for, the system Voltage is something that really needs to be known. Likewise, the torque must be known in any mechanical transmission system so that it is strong enough and cheap enough.
But I don't think it achieves a lot to get hung up on the use of words when in fact there is no confusion about what's meant. Seriously, is there a better word than 'transmit' to describe what happens when a force / torque is applied somewhere and turns up somewhere else? Trans and Mission imply sending across; what else would we want to say?
What I mean is that in the case mentioned, the particles making up the driver exert forces on the pump, and therefore "transmit" torques to the pump.
I guess you can also view this as a transfer of angular momentum.
$$\Delta \vec L=\int\limits _i ^f \vec \tau_{driver} dt$$
In the equation above, the torque of the driver changes the angular momentum
$$\vec \tau_{pump} = \lim_{\Delta t \to 0} \frac{\Delta \vec L}{\Delta t}$$
which subsequently creates a torque on the pump.
Related to Transmitting Torque: Meaning & Why Not Power?
1. What is the meaning of transmitting torque?
Transmitting torque refers to the transfer of rotational force or energy from one component to another. It is commonly used in mechanical systems to transmit power and motion.
2. How is torque different from power?
Torque is a measure of the rotational force applied to an object, while power is a measure of the rate at which work is done. Torque is measured in units of force multiplied by distance, while power is measured in units of work divided by time.
3. Why is torque often preferred over power in certain applications?
Torque is often preferred over power in applications where a strong rotational force is needed, such as in vehicles or industrial machinery. This is because torque can directly affect an object's ability to rotate, while power may not always result in a significant change in rotational motion.
4. What factors affect the amount of torque transmitted?
The amount of torque transmitted depends on several factors, including the distance between the point of application and the axis of rotation, the amount of force applied, and the type of material and surface conditions of the components involved.
5. What are some common methods for transmitting torque?
Some common methods for transmitting torque include gears, belts, chains, and shafts. These methods use different mechanisms to transfer rotational force from one component to another, depending on the specific application and requirements.
  • Mechanics
  • Mechanics
