Travel in Space: Electric or Fuel?
  • Thread starter Karoka
  • Tags
    Space
In summary: It involves using a strong magnetic field to create a phase-shifted electromagnetic wave that can propel a spacecraft forward, without the need for propellant or reaction mass. However, this technology is still in the theoretical stages and has not been tested or proven to be feasible.
Karoka
Hi, I wanted to ask a basic question.
Can you travel in space using only electricity...? I mean, I only know rockets and Ion trusters. You need fuel for rockets and you need some kind of gas on Ion trusters that can be ionized.
Astronomy news on Phys.org
In order to accelerate you need some sort of impulse. Any suggestions as to how to do it with electricity?
Light has momentum, so if you use the electricity to run a flashlight you could veeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeery slowwwwwwwwwwwwwwwwly move a spaceship.
But the basic answer to your basic question is yes, you can use only electricity to "travel in space".
Of course if you had an unimaginably powerful flashlight with an unimaginably powerful electricity source, you could theoretically actually have a practical space propulsion system. The power source would have to be so powerful though that you would still require a substantial loss of mass to run it (e=mc^2).
Phase-shifted electrodynamic propulsion is a conceptual idea for long journeys in deep space using only electricity.
FAQ: Travel in Space: Electric or Fuel?
What is the difference between electric and fuel-powered travel in space?
Electric travel in space involves using electricity to power spacecraft, while fuel-powered travel involves using chemical reactions to produce thrust.
Which method of space travel is more cost-effective?
Electric travel in space is typically more cost-effective in the long run, as it requires less fuel and has lower operational costs. However, the initial investment in electric propulsion technology can be higher.
What are the advantages of using electric propulsion in space travel?
Electric propulsion offers many advantages, including higher efficiency, longer operational lifespan, and the ability to carry more payload. It also allows for more precise control and maneuverability in space.
Are there any limitations to using electric propulsion in space?
While electric propulsion is highly efficient, it typically produces lower thrust compared to fuel-powered engines. This can make it unsuitable for missions that require high speeds or quick acceleration.
What is the future of space travel? Will electric propulsion become the norm?
There is a growing interest in using electric propulsion for space travel, especially for long-distance missions. However, it is unlikely to completely replace fuel-powered engines, as both methods have their own advantages and limitations. It is likely that a combination of both technologies will be used in the future for different types of space missions.
