Intuitive
- 270
In certain regions of outer space the temperature is about 3 K, and there are approximately 5 x 106 molecules per cubic meter or 5 atoms/cm3.
Light travels approximately 29,979,342,835.2 cm per second.
If we Cube the volume area to be cm3 and multiplied by 5 Atoms according to the cm3 Length of 29,979,342,835.2 cm per second then the Light should pass by as many as 149,896,714,176 Atoms along its path in one second which should by these calculations that Light is always traveling in a Fluidic medium even when in areas of Space containing only 1 Atom/m3 for deep Space which would be 299,793,428.352 Atoms per second that Light passes by.
There are 602,200,000,000,000,000,000,000 Atoms or 6.022 x 10^23 Atoms in one Gram of Hydrogen which compared to our 299,793,428.352 Atoms per Second is passing by 1/2008716479578504.299928704529257 of a Gram of Hydrogen if Hydrogen was the Medium in deep Space along the path of our lights path.
The Problem gets even greater if the Volume area of a Space Ship was involved in the equation instead of just Light.
We know that in Theory that it is impossible to travel faster than Light Speed, But even if the Future does find a way to achieve such a feat the future will run into other problems the faster they achieve because the region of space will become relatively more fluidic per second.
I do not see velocity as being the answer to Space Travel because of this forseeable compression of Space with greater velocity.
This leads me to believe that Dimensional travel may be the only way around this problem and I am not to sure about this either.
