Traveling at a speed faster than light
We can never do experiments to find the "true speed of light", because we can never find out what it is. That's why we call it "the invariant speed".In summary, special relativity is not wrong because it is based on the observation that the speed of light is invariant, not that it is the largest possible speed. As a bat using echolocation, we could detect objects moving faster than the speed of sound if they emit sound and set up a network of echolocators. Similarly, as humans, we could detect objects moving faster than the speed of light if they emit light. The concept of the invariant speed applies to all frames of reference, regardless of their relative motion. This means that no matter how much we
Saurabh Kumar Singh
Imagine yourself to be bat. You can't see anything. You don't have eyes. All you can do is echolocate, using ultrasound.
Now imagine something is moving away from you faster than the speed of sound. Can you locate it ? Can you perceive its existence ?
If the answer is yes, how ?
If no , then from the bats perspective it should be highest speed that can be achieved .
Then how can we, as humans say that speed of light is maximum in the universe because we won't be able to detect anything moving faster than speed of light. So is special relativity wrong ?
Special relativity is based on the observation that the speed of light is invariant, not that it is the largest possible speed - that is a consequence of the theory.
As a bat, you might notice that the speed of sound changes depending on wind and how you move relative to it. The point is that this does not happen for light. Regardless of how you move, light always has the same speed relative to you. That is the basis of SR.
Likes Demystifier
If it doesn't emit its own sound (unlikely), then no. But since supersonic planes make noise, in real life the answer is yes.
If no , then from the bats perspective it should be highest speed that can be achieved.
Because we can detect other things besides visible light And if something moving faster than light gave off its own light, we'd see that.
Likes nitsuj
Sure. If it emits sound then you could perceive it directly. You could also set up objects that would emit sounds upon collision with the object. You could set up a network of echolocators throughout the region of interest.
Supersonic jets are very audible.
This is not correct. He speed of light is the maximum speed because it is the invariant speed, not because we could not detect faster objects. Using the methods described above we could easily detect FTL objects using light.
Even a bat, using echolocation only, with sufficiently precise measurements could determine that the speed of sound is not invariant and that there is a finite speed which is invariant. They would simply call that speed "the invariant speed" rather than "the speed of light". Nothing about SR would change
Likes Vanadium 50
@Saurabh Kumar Singh:
Imagine that you're sitting on the ground and a beam of light shoots past you, from east to west. How fast would you say it's moving? Obviously you'd say it's moving at the speed of light (##c##), yes?
Now, imagine that while this is happening, your friend Alice flies past you on a rocket traveling at three-fourths the speed of light (##3c/4##), also from east to west. How fast does Alice say the beam of light is moving? Perhaps you'd think that she says the light is moving at ##c - 3c/4 = c/4##, since she's moving in the same direction as the light. But that's not correct! For Alice, the light is moving at ##c##, just as it is for you.
That's what we mean when we say that the speed of light is invariant. Even if Alice were traveling at ##.99c## relative to you, you'd both agree that the light beam is traveling at speed ##c##.
Here is the takeaway: Alice can't "catch up" to the light. From her own perspective, she can't even begin to catch up to it! No matter how much she accelerates westward, she always measures its speed to be ##c##.
Of course, as she accelerates, you (on the ground) will say that her speed gets closer and closer to ##c##, but will you ever see her reach that speed? Well, no, because "catching up to something" isn't a matter of perspective. If you say she and the light beam are moving westward at the same speed, then from her perspective the light must be traveling at speed ##0## (not ##c##). But that violates the condition that the speed of light is invariant.
So you see, if the speed of light is invariant, then it's a speed we can never accelerate to.
Likes PAllen
Related to Traveling at a speed faster than light
What is traveling at a speed faster than light?
Traveling at a speed faster than light, also known as superluminal travel, is the concept of moving through space at a velocity greater than the speed of light.
Is traveling at a speed faster than light possible?
According to our current understanding of physics, it is not possible to travel at a speed faster than light. The speed of light, which is approximately 299,792,458 meters per second, is considered to be the ultimate speed limit in the universe.
Why is traveling at a speed faster than light not possible?
This is due to Einstein's theory of special relativity, which states that as an object's speed increases, its mass also increases. As an object approaches the speed of light, its mass becomes infinite, making it impossible for the object to reach or exceed the speed of light.
Are there any theories or concepts that allow for faster-than-light travel?
There are some theories, such as the Alcubierre drive and wormholes, that propose ways to bypass the speed of light limit. However, these are currently just theoretical and have not been proven or tested.
What are the potential consequences of traveling at a speed faster than light?
If it were possible to travel faster than light, it would violate the laws of physics as we know them. This could have unpredictable and potentially dangerous consequences, such as causing time travel paradoxes or disrupting the fabric of space-time.
