Traveling to alternate universes
  • Thread starter diezir
In summary, Max Tegmark thinks that if space-time goes on forever, it should repeat itself, which is why Stranger Things is considered science fiction.
diezir
We have a three-dimensional universe, and if we include space-time - four. So, in Stranger Things, the characters do not travel to another dimension, but rather to another version of Earth in a parallel universe. This is hypothetically true. If space-time goes on forever, it only makes sense that it should repeat itself.
Any sort of 'hypothesis' can be discussed but that doesn't imply it will "make sense". Just don't try to bring Physics into this it won't run.
Likes russ_watters
You don't seem to understand the concept of other "parallel" universes being the same thing as the multiverse and if they exist (which is doubtful) they are causally disconnected from ours. Stranger Things is FICTION. Don't try to make science out of it.
That seems to make sense to you but it makes no sense to me. The integers go on forever. Do they repeat themselves?
Likes russ_watters
Although this thread started off as a question in cosmology (sort of), it has morphed into something that should be in the science fiction forum, not cosmology.
Likes berkeman and Bystander
It's definitely possible! For example Dr Strange traveled to the dark dimension to engage Dormammu, and Scott Lang used Pym particles to enter the quantum realm.
imagIne71 said:
Summary:: How can we travel to another universe?
How can we travel from one alternate universe to another?, how could we prove that it has happened?
What "our universe" is is pretty well defined by the fact that it at least contains the part we can visit, which is part of the causally connected part of the universe. So any place we can in principle visit is already part of our universe. Other universes are causally disconnected from our universe, which we therefore can't visit.
Agreed. And moved.
Likes russ_watters and phinds
Alternative Universe? You can't get there from here.
It is also very derivative, repetitive and boring. I watched about three of the first episodes. Yawn; not enough car chases or bar fights.
  • Haha
Likes Rive
That's called 'technobabble'. You are doin' it right.
Regarding the 'repeat' thing: if you make a random series of variables: like decimals of a number there will be sequences which repeat themselves with some statistical chance. That's true.
As far as we understand now the problem with the universe - any universe - is that the possible number of values (states) its 'decimals' can take is pretty big (practically infinite). You need some infinite-on-infinite-on-infinite kind of number of repeats to have significant pieces (not the whole - just pieces) to repeat themselves.
Just keep on with the technobabble. That's more reliable. Sort of.
Likes phinds
Max Tegmark seems to think so, with some assumptions.
There is the many worlds hypothesis which says that everything that can happen (has non-zero probability according to Quantum mechanics) does happen, but reality branches off into different causally separate realms (different realms, rather than spatially separated universes or worlds). In that scenario there is a reality with every possible version of you.
Tegmark, however, argues that, given some randomness properties, and an infinite number of finitely describable universes, you get the same thing, where everything that can happen does happen in some universe.
The Multiverse Hierarchy
https://arxiv.org/pdf/0905.1283.pdf
There was a discussion on PF related to this.
https://www.physicsforums.com/threads/quantum-immortality-without-mwi.997952/
If there is an infinity of worlds then each one has zero probability. Lebesque integration was invented to deal with this.
I remain to be convinced that an infinite Universe is finitely describable.
Tegmark estimates that the nearest identical copy of you is probably only about ##10^{10^{29}}## m away in a level ##\text{I}## multiverse. But there would be many near perfect copies as well, and I'm not sure how close they would be.
FAQ: Traveling to alternate universes
How is it possible to travel to alternate universes?
There are several theories and concepts in physics that propose the existence of alternate universes, such as the multiverse theory and the many-worlds interpretation. These theories suggest that there are multiple parallel universes existing alongside our own, and it may be possible to access them through advanced technology or through natural phenomena such as black holes.
Can we actually physically travel to alternate universes?
At this point in time, there is no scientific evidence or technology that allows for physical travel to alternate universes. However, some scientists believe that it may be possible in the future through advancements in quantum mechanics and space-time manipulation.
Are there any potential dangers or consequences of traveling to alternate universes?
Since we currently have no way of physically traveling to alternate universes, it is difficult to determine any potential dangers or consequences. However, some theories suggest that traveling to alternate universes could disrupt the balance of our own universe or cause paradoxes that could have unpredictable effects.
How do alternate universes differ from our own?
Alternate universes are believed to have their own unique set of physical laws, constants, and histories. This means that everything from the fundamental particles that make up the universe to the events that have occurred in the past may be different in alternate universes.
Is it possible to interact with alternate versions of ourselves in these universes?
According to the many-worlds interpretation, every possible outcome of a situation exists in a different universe. This means that there could be alternate versions of ourselves in these universes, but it is unclear if we could ever interact with them or if they would even be aware of our existence.
