Triangle ABC: Prove cot(A/2) + cot(C/2) = 2cot(B/2)
  • MHB
  • Thread starter anemone
In summary, the equation cot(A/2) + cot(C/2) = 2cot(B/2) can be proven using the trigonometric identity for the cotangent of a half angle. It is a fundamental relationship in the study of triangles and can be applied to any triangle. This equation also has practical applications in various fields such as engineering and navigation. Other trigonometric identities, such as the law of sines and the law of cosines, can be derived from this equation and are useful in solving for unknowns in triangles.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
For a triangle $ABC$ with the sides of $a,\,b,\,$ and $c$ such that $a+c=2b$, prove \(\displaystyle \cot \frac{A}{2}+\cot \frac{C}{2}=2\cot \dfrac{B}{2}\).
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution: (Smile)
1. kaliprasad
2. greg1313
Solution from kaliprasad:
By applying the law of cotangents to the triangle $ABC$, with the standard notation $s$ to represent semi-perimeter and the area of triangle as $\triangle$, we have
$\cot(\frac{A}{2}) = \dfrac{s(s-a)}{\triangle}\cdots(1)$
$\cot(\frac{B}{2}) = \dfrac{s(s-b)}{\triangle}\cdots(2)$
$\cot(\frac{C}{2}) = \dfrac{s(s-c)}{\triangle}\cdots(3)$
Add (1) and (3) to get
$\begin{align*}\cot(\frac{A}{2}) + \cot(\frac{C}{2})&=\dfrac{s(s-a)}{\triangle} + \dfrac{s(s-c)}{\triangle}\\&=\dfrac{s(s-a)+s(s-c)}{\triangle}\\&=\dfrac{s(s-a+s-c)}{\triangle}\\&= \dfrac{s(2s-(a+c))}{\triangle}\\&= \dfrac{s(2s-2b)}{\triangle} \text{ (Given)}\\&= 2\dfrac{s(s-b)}{\triangle}\\&=2\cot(\frac{B}{2})\text{ from (2)} \end{align*}$
And we are done.
FAQ: Triangle ABC: Prove cot(A/2) + cot(C/2) = 2cot(B/2)
How do you prove the equation cot(A/2) + cot(C/2) = 2cot(B/2)?
To prove this equation, we can use the trigonometric identity for the cotangent of a half angle: cot(x/2) = (1 + cosx)/sinx. By substituting this identity into the equation, we can manipulate the terms to eventually show that both sides are equal.
What is the significance of the equation cot(A/2) + cot(C/2) = 2cot(B/2)?
This equation is significant because it is a fundamental relationship in the study of triangles. It relates the cotangent of each angle in a triangle to the cotangent of the half of the third angle, which can be useful in solving for missing side lengths or angles.
Can this equation be applied to any triangle, regardless of its shape or size?
Yes, this equation can be applied to any triangle, as long as the angles A, B, and C are all less than 180 degrees. It is a general relationship that holds true for all triangles.
How can this equation be used in real-world applications?
This equation can be used in various fields such as engineering, navigation, and physics. For example, it can be used to calculate distances or angles in surveying or map making, or to determine the forces acting on an object at an angle.
Are there any other trigonometric identities that can be derived from this equation?
Yes, there are other identities that can be derived from this equation, such as the law of sines and the law of cosines. These identities are useful in solving for unknown side lengths or angles in triangles.
