Triangle Challenge: Prove 2.5<PQ/QR<3
In summary, the Triangle Challenge is a mathematical problem that involves proving a specific inequality among the sides of a triangle. It is important for developing critical thinking skills and demonstrating the use of mathematical proofs. To prove the inequality 2.5<PQ/QR<3 in a triangle, one would need to use the triangle inequality theorem and the concept of similar triangles. This inequality can be proven for any type of triangle, and it has many real-life applications in fields such as engineering, architecture, and navigation. By practicing problems like the Triangle Challenge, individuals can improve their problem-solving skills and develop a stronger understanding of mathematical concepts.
anemone
MHB
POTW Director
3,883
115
In a triangle $PQR$ right-angled at $R$, the median through $Q$ bisects the angle between $QP$ and the bisector of $\angle Q$.
Prove that $2.5<\dfrac{PQ}{QR}<3$.
Mathematics news on Phys.org
My solution:
Please refer to the following diagram:
We see that:
\(\displaystyle \sec^2(4\alpha)=\left(\frac{\overline{PQ}}{\overline{QR}}\right)^2\)
And we also find:
\(\displaystyle 4\tan^2(3\alpha)+1=\left(\frac{\overline{PQ}}{\overline{QR}}\right)^2\)
And so this implies:
\(\displaystyle f(\alpha)=4\tan^2(3\alpha)-\sec^2(4\alpha)+1=0\)
Using a numeric root-finding technique, we find the smallest positive root (the only applicable root) is:
\(\displaystyle \alpha\approx0.29630697598921511618\)
And thus:
\(\displaystyle \sec(4\alpha)\approx2.6589670819169940791\)
Hence:
\(\displaystyle 2.5<\frac{\overline{PQ}}{\overline{QR}}<3\)
Thanks, MarkFL for participating and the really smart and intelligent way to prove this challenge! :cool:
I want to share the solution of other too:
If we use MarkFL's provided diagram, the Sine rule tells us, both from triangles $PQS$ and $QSR$ that
$\dfrac{QS}{\sin P}=\dfrac{PS}{\sin \theta}$
$\dfrac{QS}{\sin 90^{\circ}}=\dfrac{RS}{\sin 3\theta}$
Since $PS=RS$, we obtain $\sin 3\theta \sin P=\sin \theta$. However, $P=90^{\circ}-4\theta$, thus we get $\sin 3\theta \cos 4\theta=\sin \theta$.
Note that
$\dfrac{PQ}{QR}=\dfrac{1}{\cos 4\theta}=\dfrac{\sin 3\theta}{\sin \theta}=3-4\sin^2 \theta$
This shows that $\dfrac{PQ}{QR}<3$.
Using $\dfrac{PQ}{QR}=3-4\sin^2 \theta$, it's easy to compute $\cos 2\theta=\dfrac{\dfrac{PQ}{QR}-1}{2}$.
Hence,
$\dfrac{QR}{PQ}=\cos 4\theta=\dfrac{1}{2}\left(\dfrac{PQ}{QR}-1\right)^2-1$
Suppose $\dfrac{PQ}{QR}\le 2.5=\dfrac{5}{2}$. Then $\left(\dfrac{PQ}{QR}-1\right)^2\le \dfrac{9}{4}$ and $\dfrac{QR}{PQ}\ge \dfrac{2}{5}$.
Thus,
$\dfrac{2}{5}\le \dfrac{QR}{PQ}=\dfrac{1}{2}\left(\dfrac{PQ}{QR}-1\right)^2-1\le \dfrac{9}{8}-1=\dfrac{1}{8}$, which is absurd.
We conclude then that $\dfrac{QR}{PQ}>\dfrac{5}{2}$ and the proof is done.
FAQ: Triangle Challenge: Prove 2.5<PQ/QR<3
What is the Triangle Challenge and why is it important?
The Triangle Challenge is a mathematical problem that involves proving a specific inequality among the sides of a triangle. It is important because it helps develop critical thinking skills and demonstrates the use of mathematical proofs.
How do you prove that 2.5
To prove this inequality, you would need to use the triangle inequality theorem, which states that the sum of any two sides of a triangle must be greater than the third side. You would also need to use the concept of similar triangles and the properties of proportions.
Can this inequality be proven for any type of triangle?
Yes, this inequality can be proven for any type of triangle, including acute, right, and obtuse triangles. However, the approach to proving it may differ slightly depending on the type of triangle.
What are some real-life applications of this Triangle Challenge?
This Triangle Challenge has many real-life applications, such as in engineering, architecture, and navigation. For example, engineers may use this concept to determine the strength and stability of a structure, architects may use it to design triangular-shaped buildings, and navigators may use it to calculate distances and angles on a map.
How can I improve my problem-solving skills through this Triangle Challenge?
Practicing mathematical proofs, such as this Triangle Challenge, can help improve problem-solving skills by requiring logical reasoning, critical thinking, and attention to detail. By tackling challenging problems like this, you can develop a stronger understanding of mathematical concepts and improve your problem-solving abilities.
