MHB Triangle Inequality Proof for Side Lengths of Triangle ABC
The discussion focuses on proving the inequalities related to the side lengths of triangle ABC, specifically the expressions involving the square roots of the products of the sides. The left side of the inequality, \( \sqrt{ab} + \sqrt{bc} + \sqrt{ca} \leq a + b + c \), is established using the Cauchy-Schwarz inequality. For the right side, \( a + b + c < 2\sqrt{ab} + 2\sqrt{bc} + 2\sqrt{ca} \), the proof involves manipulating the triangle's properties and applying the AM-GM inequality. The discussion emphasizes the importance of these inequalities in understanding the relationships between the sides of a triangle. Overall, the proofs highlight fundamental geometric principles.
Albert1
Triangle ABC with side lengths a,b,c please prove :
$ \sqrt {ab}+\sqrt {bc}+\sqrt {ca}\leq a+b+c<2\sqrt {ab}+2\sqrt {bc}+2\sqrt {ca}$
Mathematics news on Phys.org
proof of left side:
$2\sqrt {ab}\leq a+b----(1)$
$2\sqrt {bc}\leq b+c----(2)$
$2\sqrt {ca}\leq c+a----(3)$
(1)+(2)+(3):$2(\sqrt {ab}+\sqrt {bc}+\sqrt {ca})\leq 2(a+b+c)$
$\therefore \sqrt {ab}+\sqrt {bc}+\sqrt {ca}\leq a+b+c$
Albert said:
proof of left side:
proof of right side:
let: $a\leq b\leq c$
$\sqrt {ab}+\sqrt {bc}\geq a+b-----(4)$
$\sqrt {bc}+\sqrt {ca}\geq a+b-----(5)$
$\sqrt {ca}+\sqrt {ab}\geq a+a-----(6)$
(4)+(5)+(6):
$2(\sqrt {ab}+\sqrt {bc}+\sqrt {ca})> 2a+2c>a+b+c$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
