Triangle law of vector addition and the Pythagoras theorem
In summary, the triangle law of vector addition states that if three points are given in Euclidean space, the sum of two vectors connecting these points is equal to the third vector. This can be applied to find the magnitude of a resultant vector using Pythagoras's theorem, which is a special case of the cosine theorem. However, the triangle law only applies to finding the magnitude of the resultant vector, while Pythagoras's theorem also takes into account the direction. In this case, Pythagoras's theorem would be the correct method to find the magnitude of the resultant vector.
akashpandey
90
TL;DR Summary
Triangle law of vector addition and pythagoras theorem
i know its pretty basic but please give some insight for
triangle law of vector addition and pythgoras theorem.
becuase ofcourse if you use traingle law to find resultant it will be different from what is pythagoras theorem
akashpandey said:
Summary: Triangle law of vector addition and pythagoras theorem
If by "triangle law", you mean the law of cosines, check out what happens when the angle is 90 degrees.
"The triangular law" for vector addition is what happens if we add to vectors to a third vector. All have direction and length. Pythagoras is a special case of the cosine theorem. It needs a right angle, otherwise we need the cosine theorem. And even in case of a right angle, it only says something about the length of the resulting vector, nothing about direction. So "triangular law" is what happens, and Pythagoras how to calculate the length.
Suppose there is a vector a of magnitude 5 units to the east, another vector b of magnitude 6 units to the north. To find magnitude of vector a + vector b,
By the triangle law of vector addition, it is 5 + 6 units = 11 units.
By Pythagorean theorem, it is sqrt(5^2 + 6^2) = sqrt(61)
Which answer is right? If so, why is the other wrong?
Thank you!
Pythagoras is correct. There is no such thing as the "triangle law" you have quoted.
Perhaps the OP has the cosine theorem in mind?
Take three points A, B, C in Euclidean space. Then you have
$$\overrightarrow{AB}+\overrightarrow{BC}=\overrightarrow{AC}.$$
Thus
$$|BC|^2=\overrightarrow{BC}^2=(\overrightarrow{AC}-\overrightarrow{AB})^2 = |AC|^2 +|AB|^2 -2 |AC| |AB| \cos(\angle{BAC}).$$
If the angle is ##\pi/2## the cosine term vanishes, and you have Pythagoras's Theorem as a special case.
FAQ: Triangle law of vector addition and the Pythagoras theorem
What is the Triangle Law of Vector Addition?
The Triangle Law of Vector Addition states that when two vectors are represented as sides of a triangle, the resultant vector can be found by drawing the third side of the triangle. This resultant vector is equal to the sum of the two original vectors.
How is the Triangle Law of Vector Addition used in real life?
The Triangle Law of Vector Addition is used in various fields such as physics, engineering, and navigation. It is used to calculate the net force acting on an object, determine the direction and magnitude of a resultant force, and find the displacement of an object.
What is the Pythagoras Theorem?
The Pythagoras Theorem states that in a right-angled triangle, the square of the length of the hypotenuse (the side opposite the right angle) is equal to the sum of the squares of the other two sides.
How is the Pythagoras Theorem used in real life?
The Pythagoras Theorem is used in various fields such as construction, architecture, and engineering. It is used to calculate the length of the diagonal of a rectangle, determine the height of a building, and find the distance between two points on a map.
What is the relationship between the Triangle Law of Vector Addition and the Pythagoras Theorem?
The Triangle Law of Vector Addition is a special case of the Pythagoras Theorem. When two vectors are at right angles to each other, the resultant vector can be found using the Pythagoras Theorem. This is because the two vectors form the two legs of a right-angled triangle, and the resultant vector is the hypotenuse.
