Triangle length and largest angle
In summary, the homework statement is that a triangle has sides of length (n2+n+1), (2n+1) and (n2-1), where n > 1. The side (n2+n+1) must be the longest side of the triangle, and the largest angle, θ, of the triangle is 120º.
314Jason
A triangle has sides of length (n2+n+1), (2n+1) and (n2-1), where n > 1.
(a) Explain why the side (n2+n+1) must be the longest side of the triangle
(b) Show that the largest angle, θ , of the triangle is 120º.
In a triangle of sides a, b and c: a - b < c < a + b.
(a)
n2+n+1 > 2n+1
n2-n > 0
n(n-1) > 0
Thus, n < 0, n > 1.
n2+n+1 > n2-1
n+1 > -1
n > -2
I thought they would both give n > 1. I don't know what other way to show this is true.
(b) I have no idea what to do here. I thought about vectors, but don't know where to go from there.
I got (b)! I can just public the sides into the cos rule and rearrange to find theta. The n should cancle out.
Does anyone know how to do (a)? Please?
First of all, it should be immediately obvious that for n>1,
(n2+n+1) > (n2-1)
Now all you need to prove is that for n>1,
(n2+n+1) > (2n+1)
Consider the opposite proposition: (n2+n+1) [itex]\leq[/itex] (2n+1)
and solve the inequality. What's the possible range for n you get?
Hi 314Jason! :smile:
…(a)
n2+n+1 > 2n+1
n2-n > 0
n(n-1) > 0
Thus, n < 0, n > 1.
n2+n+1 > n2-1
n+1 > -1
n > -2
but you have proved it …
you've proved it's true if {n < 0 or n > 1} and {n > -2} …
so, in particular, it's true for {n > 1} ! :wink:
This is what comes of not reading the OP thoroughly. :redface:
So because n > 1 is in both equations, this is true?
yes, the question specifies that n > 1, so you only have to prove it for n > 1 :wink:
Ok then, thanks!
FAQ: Triangle length and largest angle
What is the formula for finding the length of a triangle's longest side?
The formula for finding the length of the longest side, or the hypotenuse, of a right triangle is c = √(a² + b²), where a and b are the lengths of the other two sides.
How do you determine the largest angle of a triangle?
To determine the largest angle of a triangle, you can use the law of cosines: cos(A) = (b² + c² - a²) / (2bc), where A is the largest angle and a, b, and c are the lengths of the triangle's sides. Alternatively, you can use the law of sines and compare the ratios of the angles to the ratios of the opposite sides.
Can a triangle have more than one largest angle?
No, a triangle cannot have more than one largest angle. By definition, a triangle has three angles that must add up to 180 degrees. Therefore, only one angle can be the largest.
What is the relationship between the length of a triangle's sides and its largest angle?
The length of a triangle's sides is directly related to its largest angle. The larger the length of the longest side, the larger the largest angle will be. This is because the longest side is opposite the largest angle in a triangle.
Can the largest angle of a triangle be greater than 90 degrees?
Yes, the largest angle of a triangle can be greater than 90 degrees. This type of triangle is called an obtuse triangle. In an obtuse triangle, one angle is greater than 90 degrees and the other two angles are acute, or less than 90 degrees.
