Triangle Point Conjecture: Proving $\angle BPC+\angle BAC=180^\circ$ | POTW #209
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, the Triangle Point Conjecture states that in any triangle ABC, if a point P is chosen on the circumcircle of the triangle, then the sum of angles BPC and BAC will always equal 180 degrees. It is an important tool for proving geometric theorems and solving problems. The conjecture can be proven using geometric constructions and mathematical reasoning. Real-life applications include engineering, architecture, and navigation. There are no exceptions to the Triangle Point Conjecture for triangles on a flat plane, but it does not hold true for spherical triangles.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
-----Let $ABC$ be a triangle with $AC$ is longer than $AB$. The point $X$ lies on the side $BA$ extended through $A$, and the point $Y$ lies on the side $CA$ in such a way that $BX=CA$ and $CY=BA$. The line $XY$ meets the perpendicular bisector of the side $BC$ at $P$. Show that $\angle BPC+\angle BAC=180^\circ$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
No one answered last week problem. :(
You can see the proposed solution as follows:
Let the bisector of $\angle A$ meets $BC$ at $D$ ad extend $XY$ to meet $BC$ at $E$.
Triangle $XAY$ is isosceles since $AX=BX-BA=CA-CY=AY$, hence $\angle AXY=\angle AYX$. The exterior angle of triangle $XAY$ at $A$ is $\angle A$, so $\angle A=2\angle AXY \implies \angle AXY=\angle BAD$. This suggests $AD$ is parallel to $XY$ and therefore we have
\(\displaystyle \frac{DE}{BD}=\frac{AX}{AB}\) (1)
Since $AD$ bisects $\angle A$, the following is also true:
\(\displaystyle \frac{DC}{BD}=\frac{AC}{AB}\) from which we then obtain:
\(\displaystyle \frac{DC-BD}{BD}=\frac{AC-AB}{AB}=\frac{AC-CY}{AB}=\frac{AY}{AB}=\frac{AX}{AB}\) (2)
From (1) and (2) we have
$DE=DC-BD$
But $DE=DC-EC$ so we can deduce $BD=EC$.
Let $M$ be the midpoint of $BC$. Then $M$ is also the midpoint of $DE$ and triangle $PDE$ is isosceles.
$\angle PED=\angle ECY+\angle CYE=\angle BCA+\angle AYX=\angle C+\frac{\angle A}{2}=\angle PDE$
Consequently,
$\angle DPE=\pi-2\angle C-\angle A=180^\circ-\angle C-\angle A-\angle C=\angle B-\angle C$ and so \(\displaystyle \angle DPM=\frac{\angle B-\angle C}{2}\)
Then
\(\displaystyle \tan \angle DPM=\frac{DM}{PM}\)
\(\displaystyle \begin{align*}PM&=DM \cot \angle DPM=(BM-BD)\cot \left(\frac{\angle B-\angle C}{2}\right)\\&=\left(\frac{a}{2}-\frac{ac}{b+c}\right)\cot \left(\frac{\angle B-\angle C}{2}\right)\\&=\frac{a(b-c)}{2(b+c)}\cot \left(\frac{\angle B-\angle C}{2}\right)\end{align*}\)
where $a,\,b$ and $c$ are the sides of triangle $ABC$.
We then make the substitution \(\displaystyle \frac{b-c}{b+c}=\frac{\tan \left(\frac{\angle B-\angle C}{2}\right)}{\tan \left(\frac{\angle B+\angle C}{2}\right)}\) to get
\(\displaystyle PM=\frac{a}{2\tan \left(\frac{\angle B+\angle C}{2}\right)}\)
or \(\displaystyle \tan \left(\frac{\angle B+\angle C}{2}\right)=\frac{\frac{a}{2}}{PM}=\frac{BM}{PM}\)
Also, \(\displaystyle \tan \angle BPM=\frac{BM}{PM}\) so
\(\displaystyle \tan \left(\frac{\angle B+\angle C}{2}\right)=\tan \angle BPM=\tan \frac{\angle BPC}{2}\)
From this it follows that \(\displaystyle \angle BPC=\angle B+\angle C\) and therefore we have \(\displaystyle \angle BPC+\angle BAC=\angle B+\angle C+\angle A=180^\circ\)
FAQ: Triangle Point Conjecture: Proving $\angle BPC+\angle BAC=180^\circ$ | POTW #209
What is the Triangle Point Conjecture?
The Triangle Point Conjecture states that in any triangle ABC, if a point P is chosen on the circumcircle of the triangle, then the sum of angles BPC and BAC will always equal 180 degrees.
Why is the Triangle Point Conjecture important?
The Triangle Point Conjecture is important because it provides a useful tool for proving various geometric theorems and solving geometry problems.
How can the Triangle Point Conjecture be proven?
The Triangle Point Conjecture can be proven using a combination of geometric constructions and mathematical reasoning. One approach is to draw a line through P parallel to side BC and use properties of parallel lines to show that angles BPC and BAC are supplementary.
What are some real-life applications of the Triangle Point Conjecture?
The Triangle Point Conjecture can be applied in fields such as engineering, architecture, and navigation, where geometric principles are used to solve practical problems.
Are there any exceptions to the Triangle Point Conjecture?
No, the Triangle Point Conjecture holds true for all triangles and points P on the circumcircle. However, it only applies to triangles on a flat plane and does not hold true for spherical triangles.
