Triangle problem, finding unknown sides
  • Thread starter LogarithmLuke
  • Tags
    Triangle
In summary, Alexander has a 6.0m long pole and wants to use it to create a right triangle. With one leg already measuring 2.0m, the other leg and hypotenuse can be calculated using the Pythagorean theorem. By setting the other leg as x and the hypotenuse as 6-x, a equation can be set up to solve for x. Simplifying the equation leads to x=1.5 and the hypotenuse being 2.5m.
LogarithmLuke
83
Alexander has a 6.0m long pole. He wants to use the pole to make a right triangle. One of the legs, meaning not the hypotenuse, is 2.0m long. Calculate the length of the tho other sides in the triangle.
Phytagorah theorem asquared + b squared is equal to c squared.
What i did was i tried to set up an equation. I wrote the other leg as x, and the hyoptenuse as 6-x because it was originally a 6m long pole. I then had 2squared+xsquared equal to 6-xsquared. I found that x is equal to the squareroot of 2 which is not correct and i do not know how to get further.[/B]
What i did was i tried to set up an equation. I wrote the other leg as x, and the hyoptenuse as 6-x because it was originally a 6m long pole. [/B]
What about the other 2 m long leg?
Instead of making the hypotenuse 6-x try 4-x because you already used 2 up in the other leg.
Other 2m long leg? We only know that one side is 2m.
think about what you have.
The formula for adding up all the sides of a right triangle is
a + b + c = Perimeter
You know the total Perimeter is going to equal 6
2 + b + c = 6
You know the formula for a right triangle is
(a^2) + (b^2) = (c^2)
Is there something you can do with these two equations?
2^2+b^2=6^2 ?
LogarithmLuke said:
2^2+b^2=6^2 ?
Close but no cigar.
Look at the perimeter formula again.
2 + b + c = 6
What does this really mean? A side that is 2 units long, plus another side, plus the largest the side, is all equal to 6. What happens if we try to isolate for something here and rearrange this formula a bit.
We know these individual pieces are related to each other and they all add up to six right? What happens if we isolate one of the unknown pieces and try to get it by itself?
2 + b + c = 6
2 + b + c - 2 = 6 - 2
b + c = 4
c = 4 - b
We have isolated c which is our hypotenuse variable. This statement reads "The hypotenuse is equal to 4 units minus some unknown number of units"
Now back to our right triangle formula.
We know one of the sides is 2 meters right? How bought we assign our known "2 unit" long section to the "a" variable. Like in your post above.
How does this look?
(2^2) + (b^2) = (c^2)
Do you notice something that we can do with our isolated " c" variable from earlier?
c = 4 - b
What can you do with these two formulas? Hint: the c here is the exact same as the squared c that is in the Pythagorean formula.
I feel really stupid but i can't seem to figure it out. I guess you could do c^2=2^2-b^2 but then you have 2 variables in one equation. Are you 100% sure the prerimeter has to be 6 though? when you bend the sides won't the total length be changed somewhat?
The sides are not bent. They are folded at angles.The sides of a triangle are constant and do not bend. Take a piece of string and arrange it in the shape of a triangle. Does the amount of string ever change?
and
c = 4 - b
I'll give you another step.
(2^2) + (b^2) = ((4 - b)^2)
Do you see what I've done?
a2 + b2 = c2
Ok so here what you know the total length of the pole is 6m. You also know that at least one side but not the hypotenuse has a length of 2m you can set this to either a or b.
a=2
because side a is taking up at least 2m then remaining is now 4m what ever length side b is we will have to subtract from the remaining length thus leaving us with side c so we can say c=4-b
a2 + b2 = c2
Plug in
22 + b2 = (4-b)2
Simplify
4 + b2 = b2-8b+16
then just solve for b
Ahh i get it now, thanks for the help guys :)
So, what did you get for a result ?
B is 1.5, hypotenuse then has to be 2.5
Likes ConstantineO and SammyS
Related to Triangle problem, finding unknown sides
1. How do you find the missing side in a right triangle?
To find the missing side in a right triangle, you can use the Pythagorean theorem. This theorem states that in a right triangle, the square of the length of the hypotenuse (the side opposite the right angle) is equal to the sum of the squares of the other two sides. So, if you know the lengths of two sides, you can use this formula to solve for the missing side.
2. Can you use trigonometric ratios to find the missing side in any triangle?
Yes, you can use trigonometric ratios (sine, cosine, and tangent) to find the missing side in any triangle, not just right triangles. For example, if you know the length of one side and an angle, you can use the sine ratio to find the length of the opposite side.
3. What is the Law of Cosines and how is it used to find a missing side?
The Law of Cosines is a formula used to find the length of a missing side in any triangle. It states that the square of a side is equal to the sum of the squares of the other two sides, minus two times the product of the two sides and the cosine of the included angle. This formula can be used when you know the lengths of two sides and the angle between them.
4. Is it possible to find the missing side in a triangle if only the angles are known?
No, it is not possible to find the length of a missing side in a triangle if only the angles are known. In order to find a missing side, you need at least one known side or one known side and one known angle.
5. Can you use the Pythagorean theorem to find the missing side in any triangle?
No, the Pythagorean theorem can only be used to find the missing side in a right triangle. It cannot be applied to any other type of triangle.
9K
