Triangle Side and Angle Relationship Problem #121 - July 21st, 2014
  • MHB
  • Thread starter anemone
In summary, the conversation discusses a problem involving the relationship between the sides and angles of a triangle, specifically for the 121st problem on July 21st, 2014. To solve this type of problem, one should identify the given information and use relevant geometric formulas and laws, such as the Pythagorean theorem or the law of sines and cosines. Common mistakes when solving these problems include using the wrong formula, misinterpreting information, and making calculation errors. Tips for solving these problems include drawing a diagram and practicing using relevant formulas and laws. An example solution for the specific problem is provided, using the law of cosines to find the remaining angle of a triangle with given side lengths and an angle.
anemone
MHB
POTW Director
3,883
115
Let $x,\,y,\,z$ be the three sides of a triangle, and let $a,\,b,\,c$ represents the angles opposite them.
If $x^2+y^2=1989z^2$, find $\dfrac{\cot a+\cos b}{\cot c}$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Hi MHB,
I'm so glad that Opalg has wrote to me that has brought me to the attention that there might be a misprint in this week high school POTW and he was right. The $\cos b$ as stated in second term in the sum of the numerator should be a $\cot b$.
I'm terribly sorry that this kind of typo/mistake happened again.
The corrected version of the problem is shown as followed:
If $x^2+y^2=1989z^2$, find $\dfrac{\cot a+\cot b}{\cot c}$.
Congratulations to the following members for their correct solutions:
1. Opalg
2. lfdahl
3. MarkFL
I'll show the solutions from all of these three members because each of them adopted different approach to solve for the problem.(Yes)
Here is Opalg's solution:
By the cosine rule, $$(1) \qquad \cos a = \frac{y^2+z^2-x^2}{2yz}.$$ Divide through by $\sin a$: $$(2) \qquad \cot a = \frac{y^2+z^2-x^2}{2yz\sin a}.$$ Next, the area of the triangle is $$(3)\qquad \text{Area} = \tfrac12yz\sin a = \tfrac12xz\sin b = \tfrac12xy\sin c.$$ Therefore $$(4)\qquad yz\sin a = xz\sin b = xy\sin c.$$ Substitute (4) into (2): $$(5)\qquad \cot a = \frac{y^2+z^2-x^2}{2xy\sin c}.$$ In exactly the same way as steps (1) - (5), but starting with the cosine rule for $\cos b$, $$(6)\qquad \cot b = \frac{x^2+z^2-y^2}{2xy\sin c}.$$ Add (5) and (6): $$(7)\qquad \cot a + \cot b = \frac{z^2}{xy\sin c}.$$ Now go back to the cosine rule in the triangle once again, using the information that $x^2+y^2 = nz^2$ (writing $n$ for $1989$ for convenience): $$(8)\qquad z^2 = x^2 + y^2 - 2xy\cos c = nz^2 - 2xy\cos c.$$ Therefore $$(9)\qquad xy\cos c = \frac{(n-1)z^2}2.$$ It follows that $$(10)\qquad xy\sin c = \frac{xy\cos c}{\cot c} = \frac{(n-1)z^2}{2\cot c}.$$ Now substitute (10) into (7): $$(11)\qquad \cot a + \cot b = \frac{2z^2\cot c}{(n-1)z^2},$$ and finally $$(12)\qquad \frac{\cot a + \cot b}{\cot c} = \frac2{n-1} = \frac2{1988} = \frac1{994}.$$
Here is lfdahl's solution:
The law of cosines:
\[cos\: a= \frac{y^2+z^2-x^2}{2yz}\\\\ cos\: b=\frac{x^2+z^2-y^2}{2xz}\\\\ cos\: c=\frac{x^2+y^2-z^2}{2xy}\]
The law of sines:
\[\frac{x}{sin\: a}=\frac{y}{sin\: b}=\frac{z}{sin\:c}\\\\ z = y\: \frac{sin\:c}{sin\:b}=x\: \frac{sin\:c}{sin\:a}\]
Thus:
\[cos\:a = \frac{y^2+z^2-x^2}{2yz}=\frac{y^2+z^2-x^2}{2yx\:\frac{sin\:c}{sin\:a}}\Rightarrow cot\: a = \frac{y^2+z^2-x^2}{2xy\: sin\:c}\\\\ cos\:b = \frac{x^2+z^2-y^2}{2xz}=\frac{x^2+z^2-y^2}{2xy\:\frac{sin\:c}{sin\:b}}\Rightarrow cot\:b = \frac{x^2+z^2-y^2}{2xy\: sin\:c}\\\\ cos\:c = \frac{x^2+y^2-z^2}{2xy}\Rightarrow cot\:c = \frac{1988z^2}{2xy\:sin\:c}\]
- where I have used the identity: $x^2+y^2 = 1989z^2$.
\[\frac{cot\:a+cot\:b}{cot\:c}=\frac{\frac{y^2+z^2-x^2}{2xy\:sin\:c}+\frac{x^2+z^2-y^2}{2xy\:sin\:c}}{\frac{1988z^2}{2xy\:sin\:c}}=\frac{y^2+z^2-x^2+x^2+z^2-y^2}{1988z^2}\\\\= \frac{2z^2}{1988z^2}=\frac{1}{994}.\]
And here is MarkFL's solution:
Let's begin with:
\(\displaystyle \cot(a)+\cot(b)=\frac{\cos(a)}{\sin(a)}+\frac{\cos(b)}{\sin(b)}=\frac{\sin(a)\cos(b)+\cos(a)\sin(b)}{\sin(a)\sin(b)}\)
Using the angle sum identity for sine, we may now write:
\(\displaystyle \cot(a)+\cot(b)=\frac{\sin(a+b)}{\sin(a)\sin(b)}\)
Now, since we know:
\(\displaystyle a+b+c=\pi\implies a+b=\pi-c\)
and coupling this with the identity:
\(\displaystyle \sin(\pi-\theta)=\sin(\theta)\)
we find:
\(\displaystyle \cot(a)+\cot(b)=\frac{\sin(c)}{\sin(a)\sin(b)}\)
Using the Law of Cosines, we may state:
\(\displaystyle z^2=x^2+y^2-2xy\cos(c)\)
We are given \(\displaystyle x^2+y^2=1989z^2\), hence:
\(\displaystyle z^2=1989z^2-2xy\cos(c)\)
\(\displaystyle xy\cos(c)=994z^2\)
\(\displaystyle \cot(c)=\frac{994z^2}{xy\sin(c)}\)
Now, we obtain:
\(\displaystyle \frac{\cot(a)+\cot(b)}{\cot(c)}=\frac{\sin(c)}{\sin(a)\sin(b)}\cdot\frac{xy\sin(c)}{994z^2}\)
The Law of Sines gives us:
\(\displaystyle \sin(c)=\frac{z}{x}\sin(a)=\frac{z}{y}\sin(b)\)
and so we now have:
\(\displaystyle \frac{\cot(a)+\cot(b)}{\cot(c)}=\frac{\frac{z}{x}\sin(a)}{\sin(a)\sin(b)}\cdot\frac{xy\frac{z}{y}\sin(b)}{994z^2}\)
\(\displaystyle \frac{\cot(a)+\cot(b)}{\cot(c)}=\frac{z^2\sin(a)\sin(b)}{994z^2\sin(a)\sin(b)}\)
Thus:
\(\displaystyle \frac{\cot(a)+\cot(b)}{\cot(c)}=\frac{1}{994}\)
FAQ: Triangle Side and Angle Relationship Problem #121 - July 21st, 2014
What is the given problem for Triangle Side and Angle Relationship #121 on July 21st, 2014?
The given problem involves determining the relationship between the sides and angles of a triangle, specifically for the 121st problem on July 21st, 2014.
How do you approach solving this type of problem?
The first step is to identify the given information, such as the measurements of the sides and/or angles of the triangle. Then, you can use the relevant geometric formulas and laws, such as the Pythagorean theorem or the law of sines and cosines, to solve for the unknown values.
What are the common mistakes made when solving these types of problems?
Some common mistakes include using the wrong formula or law, misinterpreting the given information, or making calculation errors. It is important to carefully read and understand the problem and double-check your work to avoid these mistakes.
Are there any tips or shortcuts for solving triangle side and angle relationship problems?
One tip is to draw a diagram of the triangle and label the given information before attempting to solve the problem. This can help you visualize the relationships between the sides and angles and make it easier to apply the appropriate formulas. Additionally, it can be helpful to memorize and practice using the relevant formulas and laws to become more efficient at solving these types of problems.
Can you provide an example of a solution to this specific problem (#121 on July 21st, 2014)?
Sure, here is an example solution: Given a triangle with side lengths of 4, 5, and 6, and an angle of 60 degrees opposite the side with length 5, we can use the law of cosines to solve for the remaining angle. First, we square each side length: 4^2 = 16, 5^2 = 25, and 6^2 = 36. Then, we plug these values into the formula: c^2 = a^2 + b^2 - 2abcosC. In this case, c is the side with length 6, a is the side with length 4, b is the side with length 5, and C is the angle opposite side c. So, we have 6^2 = 4^2 + 5^2 - 2(4)(5)cosC. Simplifying, we get 36 = 16 + 25 - 40cosC. This can be rearranged to solve for cosC: cosC = (16 + 25 - 36)/(-40) = 0.125. Taking the inverse cosine, we get C = cos^-1(0.125) = 82.33 degrees. Therefore, the remaining angle is approximately 82.33 degrees.
