MHB Triangle two column proof question
The discussion revolves around a proof involving triangle ABC and its bisector line BD, which is the perpendicular bisector of line AC. The original proof outlines several logical steps but receives feedback indicating that the final conclusion lacks clarity regarding the congruence of triangles ABD and CBD. The suggested revision includes establishing the congruence of these triangles based on shared sides and angles. The user seeks clarification on where their proof went wrong, particularly in the reasoning for the last step. The discussion emphasizes the importance of clearly demonstrating triangle congruence to support the conclusion that line BD bisects angle ABC.
alquix
Hello! I got a problem wrong and I'm trying to figure out what happened.
it's triangle ABC bisected by line BD
Given line BD is the perpendicular bisector of line AC, Prove line BD bisects angle ABC
I got
Step 1
Line BD is the perpendicular bisector of line AC
Reason:
Given
Step 2
Line D is the midpoint of line AC
Reason:
Definition of a perpendicular bisector
Step 3
Line segment AD and line segment CD are congruent
Reason:
Definition of midpoint
Step 4
Line BD is perpendicular to line AC
Reason:
Definition of a perpendicular bisector.
Step 5
Angle ADB and CDB are right angles
Reason:
Because they are on perpendicular lines
Step 6
Angle ADB and CDB are congruent
Reason:
Right angles are always congruent
Step 7
Line BD is congruent to itself
Reason:
Reflexive property
Step 8
Line BD bisects angle ABC
Reason:
A bisector is a line which runs through the vertex of an angle and divides the angle into two congruent angles
the feedback that I got back was "The proof is easy to follow and contains many logical steps and reasons. Revision of the last step and reasoning is needed to provide a sound logical conclusion. Congruence of triangles is mentioned but has not been clearly established."
Is anyone able to explain to me where I messed up with this? I thought I did it correctly, and I'm racking my brain here!
Mathematics news on Phys.org
I would use this as Step 8:
Triangles ABD and CBD are congruent.
Reason:
The tro triangles share two congruent sides (BD and AD, BD and DC) and one congruent angle (ADB and CDB).
Step 9:
Angles ABD and CBD are congruent.
Reason:
Step 10: you conclude.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
