Triangular prism on top of rectangular prism in the shape of a house......
In summary, the conversation was about a geometry problem involving a triangular prism on top of a rectangular prism in the shape of a house. The question was to find the area (excluding the base) and volume of the shape, as well as the ratio of a scale model's volume to the actual model's volume. The participants also discussed the missing diagram and asked for help with other related problems. The solution involved finding the area of 6 rectangles and 2 triangles, and using the scale of the model to find the ratio of the volumes. Ultimately, the answer to the question was found to be \frac{1}{24^3}.
Sting124
What formula would you use to calculate the area (excluding the base)?
What formula would you use to calculate the volume?
What would its longest side be?
Mathematics news on Phys.org
Re: triangular prism on top of rectangular prism in the shape of a house...
Do you have any information regarding the dimensions?
edit: I recently was giving a student help on a practice worksheet containing 11 problems, and this was essentially problem 10, but a diagram was missing and the question unanswerable. Are you perhaps working on the same set of practice problems?
Yes, he is the one who pointed me towards this website unfortunately this image was missing as you know, but there may be a chance to retrieve it.
If it is the shape of a house, it should still be doable.
We'd have a house with say length L and width W.
The block part of the house can have height H.
And the roof part can have height h for a total height of (H+h).
Then you'd have to calculate how much area the walls and roof have.
The slant heights are already in the question I provided for you
- slant heights 15m
- length = 48m
- Width = 24m
- height = 32m
Mark could you help my sibling over at the other forum for question 10 if not help me here please
Geometry problem please help
Shape of a house, triangular prism on top a rectangular prism
- Slant heights 15m
- length = 48m
- Width = 24m
- height = 32m
What is the area (excluding the base)?
What is the volume?
If a scale model was made with the longest side being 2m in length. What would the volume of scale model to actual model as a ratio be.
- slant heights 15m
- length = 48m
- Width = 24m
- height = 32m
Well, a house consists of 4 rectangular walls, 2 rectangular roof parts, and 2 triangular wall sections that are part of the roof.
The area of a rectangle is length x width.
The area of a triangle is base x height / 2.
Can you find the total area with this?
I just sent a PM at the other forum. (Wink)
The total area consists of 6 rectangles and 2 triangles. All measures are in meters.
There are 4 vertical rectangles making up the outer wall of the rectangular prism, 2 of these are 24 X 32 and two are 48 X 32.
There are two rectangles making up the roof, and they are 15 X 48.
There are two triangles at each end of the roof, whose height $h$ may be found using the Pythagorean theorem:
\(\displaystyle 12^2+h^2=15^2\)
Once you find $h$ then the 2 triangles have a combined area of:
\(\displaystyle A=2\left(\frac{1}{2}\cdot24h \right)=24h\)
This should allow you to find the area. Now as for the model, its longest side is 2, and the longest side of the actual shed is 48 so the scale of the mode is 1:24. When the linear measure of a 3 dimensional solid is multiplied by some factor $k$, the ratio of the volume of the original to the volume of the scaled version is then \(\displaystyle \frac{1}{k^3}\). So, what would the ratio be in this case?
FAQ: Triangular prism on top of rectangular prism in the shape of a house......
What is a triangular prism on top of a rectangular prism in the shape of a house?
A triangular prism on top of a rectangular prism in the shape of a house is a three-dimensional shape created by combining two different prisms. The rectangular prism forms the base of the house and the triangular prism is placed on top, creating the roof.
What are the properties of a triangular prism on top of a rectangular prism in the shape of a house?
The properties of this shape include a rectangular base with six rectangular faces, and a triangular roof with three rectangular faces and two triangular faces. It also has eight vertices and 12 edges.
What are the uses of a triangular prism on top of a rectangular prism in the shape of a house?
This shape is commonly used in architecture and construction to create unique and interesting roof designs for houses. It can also be used in mathematics to help students understand three-dimensional shapes.
How do you calculate the volume of a triangular prism on top of a rectangular prism in the shape of a house?
The volume of this shape can be calculated by finding the volume of the rectangular prism and the triangular prism separately, and then adding them together. The formula for the volume of a rectangular prism is length x width x height, while the formula for the volume of a triangular prism is 1/2 x base x height x length. Add the two volumes together to get the total volume of the shape.
What are some real-life examples of a triangular prism on top of a rectangular prism in the shape of a house?
Some real-life examples include A-frame houses, barns with triangular roofs, and certain types of sheds or storage buildings. This shape can also be seen in some modern and contemporary architecture designs.
