haleyking11
- 2
I'm trying to work through the below problem but it is a bit tricky and I would love any helpful tips:
A boat with a lead block on it is sitting in a pool. On the side of the boat is a red line right at the water level. On the side of the pool is a blue line right at the water level. The lead block is then tossed over the side of the boat but still connected to the boat by a string. Will the red line now be above/below or the same as the new water level? Will the blue line now be above/below or the same as the new water level?
So here is my current explanation:
The boat originally just had the force of the lead block's weight pushing directly downwards. Once the lead block is in the water, the is the force of the lead block's weight pushing downwards, but there is also some buoyant force pushing upwards. Therefore, the boat is not as heavy, resulting in the red line being above the new water level.
Because the lead block is now submerged underwater, it will cause the water levels to rise, meaning the blue line will now be below the new water level.
But I'm hesitant to put this as my answer as I feel like this could easily be a trick question. I believe this because I'm not quite sure how to relate the water displaced by the boat with the block on it compared to the water displaced by boat with the block in the water. Also, it seems contradictory for me to say that the boat will rise (resulting in a lower boat volume in the water) and yet the water level will rise as well.
Please point me in the right direction! Thanks in advance
