MHB Tricky equation a^2 = k(k-u)(k-v)(k-w) where 2k = u+v+w
  • Thread starter Thread starter Wilmer
The discussion focuses on solving the equation a^2 = k(k-u)(k-v)(k-w) with the condition 2k = u + v + w, specifically finding w given a, u, and v. The derived formula for w is w = SQRT[u^2 + v^2 + 2SQRT((uv)^2 - 4a^2], relating to Heron's formula for the area of a triangle. An example is provided where u = 4, v = 13, and w = 15 yields an area a = 24, confirming the solution. However, when u = 4 and v = 15, the expected w = 13 does not hold, prompting a review of the arithmetic. The quadratic equation derived shows two possible solutions for w, clarifying the discrepancy in the initial assumptions.
Wilmer
Given a, u and v, w = ?
Mathematics news on Phys.org
$$k = \dfrac{u+v+w}{2}$$, $$k-u = \dfrac{-u+v+w}{2}$$, $$k-v = \dfrac{u-v+w}{2}$$, $$k-w = \dfrac{u+v-w}{2}$$.
Substituting in we get
$$a^2=\dfrac{1}{16}(u+v+w)(u+v-w)(w+(u-v))(w-(u-v))$$
Simplifying yields
$$16a^2=((u+v)^2-w^2)(w^2-(u-v)^2)$$
$$-16a^2=(w^2-(u+v)^2)(w^2-(u-v)^2)$$
$$w^4-2(u^2+v^2)w^2+(u^2-v^2)^2+16a^2=0$$
This is a quadratic equation in $$w^2$$. Substitute in the values for $$a,u,v$$ and use the quadratic formula.
I was able to get to:
w = SQRT[u^2 + v^2 + 2SQRT((uv)^2 - 4a^2)]
As you probably surmised, this is Heron's triangle area in disguise!
Example: triangle sides u,v,w: u=4, v=13, w=15 : a = area = 24
My solution will give correctly w = 15 using u=4:v=13 or u=13:v=4
But not if u=4, v=15: does not yield 13
Can you tell me why...thanks in advance...
Double check your arithmetic.
With $$u=4$$, $$v=15$$ and $$a=24$$, you should get the equation
$$w^4-482w^2+52897=0$$ which factors into
$$(w-13)(w+13)(w^2-313)=0$$
This appears to yield two possible answers $$w=13$$ and $$w=\sqrt{313}$$.
Gotcha! Thanks again...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
