Tricky projectile motion question
In summary, the projectile can be safe from bombardment if it is shot from a distance of 300 m from the western shoreline on the eastern side of the mountain island.
johnyk87
An enemy ship is on the east side of a mountain island. The enemy ship has maneuvered to within 2500 m of a 1800 m high mountain peak and can shoot projectiles with an initial speed of 250 m/s. If the western shoreline is horizontally 300 m from the peak, what are the distances from the western shore at which a ship can be safe from the bombardment of the ship?
y= 250m/s*sin(x)t + .5gt^2
x= 250m/s*cos(x)t
R= v^2sin(2x)/g
I can set up the problem as a constraint problem. I tried to minimize the range formula subject to the constraint that the projectile will just go over the mountain peak as it passes. The reasoning for this is that I will be able to reduce the range of a shot by shooting it at a slightly higher angle that will just clear the peak. It is not a technical reason but it seems reasonable. I can set up the problem but isolating the angle in my constraint is tricky. Does anyone know of a better way to go about this problem?
As it follows its trajectory, the projectile can clear the mountain top on its way up ( projection angle less than 45o) or on its way down (projection angle greater than 45o). So you need to find the angles for which the projectile will just barely clear the top and then find the corresponding ranges. Then look for "blind spots" on the other side.
Thanks kuruman. I just figured it out a little while ago. I want the angle as it is coming down. For some reason i thought that there would be more than one downward angle that corresponded to just clearing the peak. Thanks again
FAQ: Tricky projectile motion question
What is projectile motion?
Projectile motion is the motion of an object through the air that is subject only to the force of gravity. It follows a curved path known as a parabola.
What factors affect projectile motion?
The factors that affect projectile motion include initial velocity, angle of launch, air resistance, and the force of gravity.
How do you calculate the range of a projectile?
The range of a projectile can be calculated using the formula R = (v2sin2θ)/g, where R is the range, v is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity.
What is the difference between horizontal and vertical components of projectile motion?
The horizontal component of projectile motion is affected only by the initial velocity, while the vertical component is influenced by both the initial velocity and the force of gravity.
How does projectile motion relate to real-life situations?
Projectile motion is commonly observed in real-life situations such as throwing a ball, shooting a basketball, or launching a rocket. It is also used in various fields of science and engineering, such as in ballistics and launching satellites into orbit.
