Trig Calculus: Solving y = sin^2(x) / cos^2 (x)
In summary: Oops.In summary, the conversation discusses finding the derivative of y = sin^2(x) / cos^2(x) using the quotient rule and converting it to tan^2(x). The correct answer is dy/dx = 2sec^2(x)tanx, but the conversation also explores an incorrect solution using the quotient rule. The mistake lies in not squaring the denominator, resulting in 2tanxsec^2x instead.
tmt1
234
Hi,
I'm working on this problem:
what is dy/dx?
In the solutions it says to convert (sin(x)/cos(x))^2=tan^2(x)
And the answer is dy/dx = 2sec^2(x)tanx
However, using the quotient rule, I got this answer:
dy/dx =[ (2sin(x)cos(x))cos^2(x) - (sin^2x)2(cos(x))(-sin(x))] / cos^2(x)
=[2sin(x)cos^2(x)+2sin^3(x)]/cos^2 (x)
Does this mean
[2sin(x)cos^2(x)+2sin^3(x)]/cos^2 (x) = 2sec^2(x)tanx ?
tmt said:
Hi,
what is dy/dx?
Does this mean
You made some mistakes with your algebra and applying the formula properly. If you use quotient rule, you should end up with
\[\begin{aligned} \frac{(2\sin x\cos x)\cos^2 x - (\sin^2 x)(2\cos x(-\sin x))}{(\cos^2 x)^2} &= \frac{2\sin x\cos^3x +2\sin^3 x\cos x}{\cos^4x} \\ &= \frac{2\sin x\cos x(\sin^2 x+\cos^2x)}{\cos^4x} \\ &= \frac{2\sin x}{\cos^3 x}\\ &= 2\frac{\sin x}{\cos x}\cdot\frac{1}{\cos^2 x}\\ &= 2\tan x\sec^2 x\end{aligned}\]
I hope this makes sense! (Smile)
You forgot to square the denominator...
FAQ: Trig Calculus: Solving y = sin^2(x) / cos^2 (x)
What is the basic concept behind trigonometric calculus?
Trigonometric calculus is the application of calculus concepts to trigonometric functions, including derivatives, integrals, and limits. It involves using trigonometric identities and properties to solve equations and analyze functions.
How is y = sin^2(x) / cos^2 (x) related to trigonometric calculus?
This equation involves both the sine and cosine functions, which are fundamental trigonometric functions used in calculus. To solve this equation, we would need to use trigonometric identities and properties, as well as techniques from calculus such as the chain rule and substitution.
What are the key steps in solving y = sin^2(x) / cos^2 (x)?
The first step is to use the quotient rule to rewrite the equation as y = (sin(x) / cos(x))^2. Then, we can use the double angle identity for sine to rewrite the equation as y = (1/2)(1 - cos(2x)) / (1/2)(1 + cos(2x)). From there, we can use other trigonometric identities and techniques from calculus to simplify and solve the equation.
How does solving trigonometric calculus problems differ from solving other types of calculus problems?
Trigonometric calculus problems often involve more complex equations and require a strong understanding of trigonometric identities and properties. They may also require more steps and techniques to solve compared to other types of calculus problems. However, the underlying principles and concepts of calculus still apply.
Why is trigonometric calculus important in the field of science?
Trigonometric calculus is used in many areas of science, including physics, engineering, and astronomy. It allows us to model and analyze the behavior of objects and systems that involve trigonometric functions, such as waves, vibrations, and rotations. It also has practical applications in fields such as navigation and surveying.
