Trig Challenge: Solutions to $\sin a \sin (2a) \sin (3a)$?
In summary, the "Trig Challenge" problem is designed to test understanding and application of trigonometric identities and properties. The best approach to solving this problem is to simplify the expression using trigonometric identities, then use algebraic manipulation and a calculator to find the solutions. There is no specific formula or method, but the double-angle and triple-angle identities can be helpful. It is acceptable to use a calculator, but it is important to show work and avoid common mistakes such as forgetting identities, making algebraic errors, and using incorrect values. The final solution should also be checked for satisfaction of the original expression.
anemone
MHB
POTW Director
3,883
115
How many solutions does the equation
$\sin a \sin (2a) \sin (3a) \cdots \sin (11a) \sin (12a) =0$
have in the interval $(0,\,\pi]$?
Mathematics news on Phys.org
It is clear that $a = \pi p/q$ for every fraction of the form $p / q$ with $1 \leq q \leq 12$, $0 < p \leq q$ is a solution to some product of the expression and hence a solution to the equation. Furthermore all solutions are of this form since $p/q \leq 1$. Hence the number of solutions to the expression is given by the length of the Farey sequence $F_{12}$ minus 1 (since it includes zero and we exclude it). Now we have:
$$\lvert F_1 \rvert = 2 ~ ~ ~ \text{and} ~ ~ ~ \lvert F_n \rvert = \lvert F_{n - 1} \rvert + \varphi(n)$$
Which gives us the general expression:
$$\lvert F_n \rvert = 1 + \sum_{m = 1}^n \varphi(m)$$
Therefore:
$$\lvert F_{12} \rvert = 1 + \varphi(1) + \varphi(2) + \cdots + \varphi(12)$$
Which gives:
$$\lvert F_{12} \rvert = 1 + 1 + 1 + 2 + 2 + 4 + 2 + 6 + 4 + 6 + 4 + 10 + 4 = 47$$
And therefore we conclude there are $46$ solutions to the original expression.
Well done, Bacterius! And thanks for participating!
The solution that I have is more or less the same as yours.:)
FAQ: Trig Challenge: Solutions to $\sin a \sin (2a) \sin (3a)$?
What is the purpose of the "Trig Challenge" problem?
The "Trig Challenge" problem is designed to test your understanding and application of trigonometric identities and properties. It requires you to use algebraic manipulation and trigonometric identities to find the solutions to the given expression.
How can I approach solving this problem?
Start by simplifying the expression using trigonometric identities such as the double-angle and triple-angle identities. Then, use algebraic manipulation to further simplify the expression. Finally, use the unit circle or a graphing calculator to find the solutions.
Is there a specific method or formula I should use to solve this problem?
There is no specific formula or method for solving this problem. It requires a combination of algebraic manipulation and knowledge of trigonometric identities. However, you can use the double-angle and triple-angle identities to simplify the expression before solving it.
Can I use a calculator to solve this problem?
Yes, you can use a graphing calculator or a scientific calculator to solve this problem. However, it is important to also show your work and explain the steps you took to arrive at the solution.
What are some common mistakes to avoid when solving this problem?
Some common mistakes to avoid when solving this problem include forgetting to use the double-angle and triple-angle identities, making algebraic errors, and using incorrect values from the unit circle. It is also important to check your final solution to ensure it satisfies the original expression.
