Trig functions cross multiplying?
In summary, the given expression can be simplified by finding a common denominator and subtracting the fractions. "Cross multiplying" does not apply to this problem.
musiclover55
trig functions cross multiplying??
sinx/cosx - 2sinxcosx/1
none??
when I cross multiply, should it be sinx-2sinxcosx/cosx or sinx-2sinxcos^2x/cosx ??
here's a pic:
http://tinypic.com/r/24fgvmv/6
none??
here's a pic:
You should forget you ever heard the term "cross multiply" since it is interfering with your understanding.
What you have is the difference of two fractions and you need to carry out the subtraction. Both addition and subtraction work the same way: find a common denominator, and once you have the common denominator in both fractions, do the subtraction.
There is no "cross multiply" in either operation.
For example, if I need to simplify 3/5 - 1/4, I would do this:
$$ \frac{3}{5} - \frac{1}{4}$$
$$ =\frac{3}{5}\cdot\frac{4}{4} - \frac{1}{4}\cdot\frac{5}{5}$$
$$ =\frac{12}{20} - \frac{5}{20} = \frac{7}{20}$$
FAQ: Trig functions cross multiplying?
What are trigonometric functions?
Trigonometric functions are mathematical functions that relate the angles of a triangle to the lengths of its sides. The most commonly used trigonometric functions are sine, cosine, and tangent.
How do you cross multiply trigonometric functions?
To cross multiply trigonometric functions, you multiply the numerator of one function by the denominator of the other function, and vice versa. Then, you set the two products equal to each other.
Why is cross multiplying used in trigonometry?
Cross multiplying is used in trigonometry to simplify equations involving trigonometric functions. It allows us to solve for unknown values and find relationships between different trigonometric functions.
What is the purpose of using trigonometric functions?
Trigonometric functions are used to model real-world situations that involve angles, such as in navigation, physics, and engineering. They are also used to solve problems involving right triangles and to analyze periodic phenomena.
What is the difference between cross multiplying trigonometric functions and regular cross multiplication?
The main difference between cross multiplying trigonometric functions and regular cross multiplication is that trigonometric functions involve angles and ratios, while regular cross multiplication involves multiplying two fractions. Additionally, in trigonometric functions, you are setting two products equal to each other to solve for unknown values, while in regular cross multiplication, you are finding the product of two fractions.
