Trig functions translations and combinations of transfomations word problems
In summary, the conversation discusses finding an equation for water depth as a function of time after low tide, drawing a graph, and using software for graphing trig functions. The equation y=5sin(pi/6)(t-3)+16 is suggested as a possible solution, and a graphing calculator is recommended for this type of problem.
Aya
46
Hi, I really need help with this question
1) the water depth in a harber is 21m at hight tide, and 11m at low tide. One cycle is completed approximatly every 12h.
a) find an equation for the water depth as a function of the time, t hours, after low tide
b) Draw a graph 48h after low tide, witch occurred at 14:00
y=asink(x-c)+d
Amplitude
a=21-11/2
a=5
K
p=2pi/k
12=2pi/k
k=2pi/12
k=pi/6
what about the c and the d??
and does anyone know of anygood software to graph trig functions?
Thanks
Someone else may be able to help you further but for now...
The 'c' is the extent to which the sine function is moved left or right (when t = 0 where is the tide?...what is the value of [tex] sin(t) [/tex] when t = 0?)
the 'd' is the extent to which the sine function is moved upwards or downwards...(without any further changes what are the maximum or minimum possible values of [tex] 5sin(t) [/tex]
as for for graphing sine functions (and many other functions) check out this free CAS :wink:
http://maxima.sourceforge.net/download.shtml
"find an equation for the water depth as a function of the time, t hours, after low tide"
In other words, when t= 0 you are at low tide. I think I would be inclined to try just y= asin(t)+ d.
HallsofIvy said:
y= asin(t)+ d.
And modify the argument to the sin() function a little to reflect the period that you are given. The argument to the sin() function should change a total of 2*Pi radians for each period which is 12 hours long.
the ansewer in the back of the book is y=5sinpi/6(t-3)+16
But waht I don't understand is how did they know that the graph is moved 3 to the right and 16 units up? I don't understand how they got these numbers from that question, if the low tide is 11m, then would'nt that be the lowest point of the graph making it be 11units up
whats the lowest point of [tex] 5sin(t)? [/tex] and what is the lowest level of the tide?...it isn't actually moved 3 to the right... it is moved [tex] \frac{\pi}{2} [/tex] rads to the right
("the ansewer in the back of the book is y=5sinpi/6(t-3)+16")
if you plotted the graph of just [tex] 5sin(\frac{t\pi}{6}) + 16[/tex] would the high and low tides occur at the correct values of t?
Thanks
You should get a graphing calculator. I recommend a TI-89 if you want to do any science later.
Related to Trig functions translations and combinations of transfomations word problems
1. What are trigonometric functions?
Trigonometric functions are mathematical functions that relate the angles of a right triangle to the lengths of its sides. The most commonly used trigonometric functions include sine, cosine, and tangent.
2. What is a translation in trigonometry?
In trigonometry, a translation refers to shifting a function horizontally or vertically on a coordinate plane without changing its shape. This can be done by adding or subtracting values to the input or output of the function.
3. How do you combine trigonometric functions?
To combine trigonometric functions, you can use trigonometric identities, which are mathematical equations that allow you to rewrite one function in terms of another. For example, the Pythagorean identity states that sin²θ + cos²θ = 1, which can be used to combine sine and cosine functions.
4. What are transformations in trigonometry?
Transformations in trigonometry refer to changes made to a function that affect its shape and position on a coordinate plane. These transformations include translations, reflections, rotations, and dilations.
5. How can trigonometry be applied to word problems?
Trigonometry can be applied to word problems in various real-life scenarios, such as finding the height of a building using the angle of elevation, or calculating the distance between two objects using the angle of depression. It can also be used in fields such as engineering, physics, and astronomy.
