Trig Functions - When wil object be 9cm below 0?
In summary, the question asks for the time, within the first 10 seconds, that a weight hanging from a spring will be 9 cm below 0. Using the equation y=12sin(Pi/5)(x), where k=Pi/5 and the vertical stretch is 12, we can solve for the time by setting y=-9 and using the inverse function of sine. This results in two answers: 6.3 seconds and 8.7 seconds.
TN17
47
Trig Functions - "When wil object be 9cm below 0?"
Here is the background information:
A weight hanging from a spring is set in motion by an upward push. It takes 10 s for the weight to complete one cycle from moving 12 cm above 0, then dropping 12 cm below 0, then returning to 0.
Here is the question:
d) In the first 10 s, when will the height of the weight be 9 cm below 0?
I found the equation to be y=12sin (Pi/5)(x)
Since k=2Pi/10 = Pi/5 and the vertical stretch is 12.
I set y=-9 because the weight is below 0, and solved for x, but I didn't know how to continue from there.
-9 = 12sin(Pi/5)(x)
There are 2 answers, 6.3 s and 8.7 s
-9 = 12sin(Pi/5)(x)
Well, solve the equation for x by the usual way- "unpeel" what has been done to x.
First, divide both sides by 12:
[tex]\frac{-9}{12}= -\frac{3}{4}= sin(\pi x/5)[/tex]
Now, use the inverse function, arcsine, to get rid of the sine function:
[tex]\frac{\pi x}{5}= arcsin(-3/4)= -0.8481[/tex]
is the "principal solution" given by a calculator. Of course, we want x to be positive so we use the fact that [itex]sin(\pi- \theta)= sin(\theta)[/itex] and, of course, [itex]sin(2\pi+ \theta)= sin(\theta)[/itex]. [itex]\pi- (-.8481)= 3.1416+ .8481= 3.9896[/itex] and [itex]2\pi+ (-.8481)= 6.2832- .8481= 5.4351[/itex]
From
[tex]\frac{\pi}{5}x= 3.9896[/tex]
and
[tex]\frac{\pi}{5}x= 5.4351[/tex]
we get
[tex]x= (3.9896)\left(\frac{5}{\pi}\right)= 6.3496[/tex]
[tex]x= (5.4251)\left(\frac{5}{\pi}\right)= 8.6502[/tex]
which round to the values you give.
Related to Trig Functions - When wil object be 9cm below 0?
1. What are trigonometric functions?
Trigonometric functions, also known as trig functions, are mathematical functions that relate the angles of a right triangle to the lengths of its sides. The most commonly used trig functions include sine, cosine, and tangent.
2. How are trig functions used in science?
Trig functions are used to model and analyze periodic phenomena in various scientific fields such as physics, astronomy, and engineering. They are also used in navigation and surveying to calculate distances and angles.
3. How do trig functions relate to the height of an object?
Trig functions can be used to calculate the height of an object at a given distance and angle. This is commonly seen in projectile motion, where the height of an object can be determined using the sine or cosine function.
4. What is the relationship between trig functions and the concept of elevation?
Trig functions can be used to calculate the elevation angle between an observer and an object. This is often used in astronomy to determine the altitude of celestial bodies.
5. When will an object be 9cm below 0 using trig functions?
This question is not complete and does not provide enough information to accurately answer. The object's position would depend on several factors such as its initial height, velocity, and acceleration. Trig functions alone cannot determine the exact position of the object.
