Trig Problem - Finding the width of a river
In summary, based on the given information and calculations, the distance across the river is approximately 272.86 meters, which does not match any of the multiple choice answers given. There may be a mistake in the interpretation of the problem or a calculation error. Further clarification or assistance is needed to determine the correct answer.
Nobuko42
1. An observer is next to a river and wants to calculate the distance across the river. He measures the angle between his observations of two points on the shore, one on his side and one on the other side, the angle coming out to be 28º. The distance between him and the point that is on the side side of him is 300 meters. The angle formed by him, the point on his side of the river, and the point directly on the opposite side of the river is 128º. What is the distance across the river?:
From what I can see, this is a trig type problem. I used the rule of triangles in where sin(A)/a = sin(B)/b = sin(C)/c to find the distance from point on the observer's side and the point on the opposite side of the river. I make A 28°, the a is my unknown distance, I make B 24° (180 - [128 + 28] = 24), and make b 300 meters, the distance from point and the observer on the same side. I get 346.27 meters for the distance between the two points on the shore of the rivers.
Given that the angle made by the observer, the point on the observer's side, and the point across, it appears that the two points are not directly across from one another, rather that the point across is further back then the point on the same side. What throws me off is the drawing for this problem, it shows that the observer and the point on the same side are right next to the river, and that the point across the right is directly across from each other, thus it looks like it should be making a 90° angle when taking those three points.
I make the conclusion that the observer and the point on his side are both next to each other, thus making a parallel line to the river when taking the 300 meter distance, meaning that the point across the river is further back.
With the 346.27 meter distance measured, I make a right triangle with the 346.27 being the hyposthus of the triangle. The angle of the point on the side of the observer, at the point is 52° (180 - 128 = 52), thus I use sin(52) = y/346.27 to find the distance across the river, getting y = 272.86 meter.
Here is my problem, there are multiple choice answers and none of them match my final answer. The possible answers are:
a) 89.7 m b) 346 m c) 179 m d) 6.4 x 10^-4 m
So I am unsure as to where my mistake may be, am I not reading the problem correctly as far as the placement of the three points, or making a calculation error. Assistance on this would be greatly appreciated, thank you.
If there's an illustration, can you post it? That would be helpful.
Now that you have the picture, you can do:
[itex]\frac{300}{sin128}=\frac{x}{sin28}[/itex]
That will give you the answer, but this is kind of broad because you can also find the distance directly across from the person, not just the hypotenuse, so it might be that answer too..
The drawing iraid made is kind of like what the problem says, except that the observer is the one on the bottom, and the two points appear to be directly across. However the drawing isn't to scale in anyway, as the angle between the observer, the point on his side, and the point across looks like 90 degrees, so it doesn't really help in regards to where each one is. I am thinking it might be the observer isn't on the shore, but somewhere down some, due to the problem saying directly across, but the drawing shows otherwise :-( on my cell so can't draw till I get home
Sorry it's not to scale, but I think that's right. The observer is the bottom dot. The answer I get is ~179 m..
Oh I didn't mean your drawing, I meant the one in the problem I have. I think your angles may not be placed correctly, as the problem says "He measures the angle between his observations of two points on the shore, one on his side and one on the other side, the angle coming out to be 28º" I think that means that the 28° is at the point of the observer, not on the point of the same side as the observer. The wording is so vague on some parts which is what is throwing me off, one part saying the two points are directly across from each other, while the other says that the observer is next to the river :\
Related to Trig Problem - Finding the width of a river
What is a "Trig Problem"?
A trig problem is a mathematical problem that involves the use of trigonometry, which is a branch of mathematics that deals with the relationships between the sides and angles of triangles.
Why would I need to find the width of a river?
Finding the width of a river can be useful for various reasons, such as determining the distance between two points on opposite sides of the river or calculating the volume of water flowing through the river.
What information do I need to solve this problem?
To solve a trig problem involving the width of a river, you will need to know the distance between two points on one side of the river, the angle of elevation from one point to the opposite side of the river, and the angle of depression from the other point to the opposite side of the river.
What trigonometric functions are used to solve this problem?
The trigonometric functions commonly used to solve this problem are sine, cosine, and tangent. These functions relate the angles and sides of a right triangle and can help you find the missing side, which in this case would be the width of the river.
Are there any special considerations to keep in mind when solving this problem?
Yes, when solving a trig problem involving the width of a river, you must make sure to use the same unit of measurement for all sides and angles. Additionally, it is important to use the correct trigonometric function for the given problem and to pay attention to the direction of the angles (elevation or depression) to ensure an accurate solution.
