Trig Question, Find x-intercepts
  • Thread starter dolpho
  • Tags
    Trig
In summary, the x-intercepts for y= -5sin(4x+pi/3) on the interval [-pi/6, pi/2) are -pi/12, pi/6, and 5pi/12. The period of the function is pi/2 and there will be an x-intercept every half-period.
dolpho
66
List all x-intercepts for y= -5sin(4x+pi/3) On the interval [-pi/6, pi/2)
I know that y=sin has x-intercepts at 0, pi, and 2pi on the interval of [0, 2pi] but when I try to solve it the same way here it doesn't really come out the same.
This is how I tried to solve it,
-pi/6 < 4x + pi/3 < pi/2 ----> I subtract pi/3 from both -pi/6 and pi/2
= -3pi/6 < 4x < pi/6 ----> Then I divide 4 by both
= -3pi/24 < x < pi / 24
so the x-intercepts would be -3pi/24 (-pi/8) and pi/24 and the midpoint between those but I guess its wrong :(
Hello dolpho. Welcome back to PF !
You're told that [itex]\displaystyle -\frac{\pi}{6}\le x\le\frac{\pi}{2}\ .[/itex] Now find the interval on which [itex]\displaystyle 4x+\frac{\pi}{3}[/itex] then occurs.
You have worked it out as if [itex]\displaystyle -\frac{\pi}{6}\le \left(4x+\frac{\pi}{3}\right)\le\frac{\pi}{2}\ .[/itex]
Ahhh my mind is messed up on this problem!
I worked it another way so that
0= -5sin(4x + pi/3)
-pi/3 = 4x
-pi/12 = x
So I think that part is right but what if I wanted to find more x-intercepts along the interval of -pi / 6 and pi/2?
0= -5sin(4x + pi/3)
-pi/3 = 4x
-pi/12 = x
[itex]\Large period=\frac{2\pi}{b}[/itex]
for the form:
[itex]\large asin(bx-c)+d[/itex]
so your b value is 4. There will be an x intercept every half-period.
0= -5sin(4x + pi/3)
-pi/3 = 4x
-pi/12 = x
You could work it out:
[itex]\displaystyle -\frac{\pi}{6}\le x\le\frac{\pi}{2}\ [/itex]
[itex]\displaystyle -\frac{4\pi}{6}\le 4x\le\frac{4\pi}{2}\ [/itex]
[itex]\displaystyle -\frac{2\pi}{3}+\frac{\pi}{3}\le 4x+\frac{\pi}{3}\le2\pi+\frac{\pi}{3}\ [/itex]
etc.
Ok so I think I found the answer.
0 = -5sin(4x+pi/3)
-pi/3 = 4x
-pi/12 = 1 x-int, Then I find out the period so, 2pi / 4 = pi/2
Add pi/2 to -pi/12 = 5pi/12. Then find the midpoint between those so the x-intercepts would be
-pi/12, pi/6 and 5pi/12
Anyone get the same answers?
0 = -5sin(4x+pi/3)
-pi/3 = 4x
Those are correct.
Related to Trig Question, Find x-intercepts
1. What is the definition of an x-intercept in trigonometry?
An x-intercept in trigonometry is the point where a trigonometric function crosses the x-axis. It is the value of x where the function's output is equal to 0.
2. How do you find the x-intercepts of a trigonometric function?
To find the x-intercepts of a trigonometric function, set the function's output equal to 0 and solve for the value of x. This can be done by using algebraic techniques or graphing the function and identifying the points where it crosses the x-axis.
3. What is the significance of x-intercepts in trigonometry?
X-intercepts are important in trigonometry because they help us determine the roots or solutions of a trigonometric equation. They also give us information about the behavior of the function, such as whether it is increasing or decreasing.
4. Can a trigonometric function have more than two x-intercepts?
Yes, a trigonometric function can have more than two x-intercepts. The number of x-intercepts a function has depends on the type and complexity of the function. For example, a sine function can have an infinite number of x-intercepts, while a tangent function can have multiple x-intercepts within a specific interval.
5. How do you use x-intercepts to graph a trigonometric function?
To graph a trigonometric function using x-intercepts, plot the x-intercepts on the x-axis and determine the behavior of the function between each intercept. You can also use the x-intercepts to identify the amplitude and period of the function. Additionally, if you know the x-intercepts and the behavior of the function, you can sketch the rest of the graph by connecting the points smoothly.
