(Trig) Rewriting using power-reducing formula?
In summary, the conversation discusses rewriting sin^4 xtan^4 x in terms of the 1st power of the cosine by using the equations sin^2 x=(1-cosx)/2 and tan^2 x=(1-cosx)/(1+cosx). The attempt at a solution involved rewriting tan^2 x as (sin^2 x/cos^2 x), but resulted in a more complicated function. The solution provided involves breaking down sin^4 x into (1-cos^2 x)^2 and then simplifying further.
yue_
Rewrite sin^4 xtan^4 x in terms of the 1st power of the cosine.
sin^2 x=(1-cosx)/2
For this problem, I tried to rewrite tan^2 x as (sin^2 x/cos^2 x)
But then I ended up with a...cubic function, which made the problem even more complicated. What am I doing wrong here?
The problem you posted was sin4(x) tan4(x). -- both with the power, 4.
Your answer still has cos3 & cos2 .
sin4(x)
= (1-cos2(x))sin2(x)
= sin2(x) - cos2(x)sin2(x)
= (1 - cos(2x))/2 - sin2(2x)/4
FAQ: (Trig) Rewriting using power-reducing formula?
What is the power-reducing formula in trigonometry?
The power-reducing formula in trigonometry is a tool used to rewrite expressions involving powers of trigonometric functions into equivalent expressions with lower powers. It is also known as the half-angle formula and is used to simplify complex trigonometric expressions.
How is the power-reducing formula derived?
The power-reducing formula is derived using the Pythagorean identities and the double angle formula. By substituting the double angle formula into the Pythagorean identities, the power-reducing formula can be obtained.
What are the common applications of the power-reducing formula?
The power-reducing formula is commonly used in calculus, physics, and engineering to simplify trigonometric expressions and make them easier to integrate or differentiate. It is also used in solving trigonometric equations and in proving trigonometric identities.
Can the power-reducing formula be used for all powers of trigonometric functions?
No, the power-reducing formula is only applicable for powers of sine and cosine functions. For other powers, different trigonometric identities or formulas may need to be used.
How can the power-reducing formula be used to simplify trigonometric expressions?
The power-reducing formula can be used by substituting the expressions with higher powers of sine and cosine into the formula, resulting in equivalent expressions with lower powers. This simplifies the expression and makes it easier to work with or evaluate.
