Trig step in a chain rule question
In summary, to show that two equations equal each other, the first equation can be squared and then expanded using the trigonometric identities for cosine and sine. This will result in a new equation that can be simplified and compared to the second equation to prove equality.
ElDavidas
80
I need to show that two equations equal one another. It's too complicated to display fully on here but I'm stuck on a step:
dF/dr = df/dx cos2(h) + df/dy sin(h)
(dF/dr)^2 = (df/dx)^2 cos^2(h) + (df/dy)^2 sin^2(h)
Does anybody know how to get rid of the cos squared and sin squared?
P.S. By (dF/dr)^2 I mean the first derivative squared not the second derivative
If
[tex]\frac{dF}{dr} = \frac{df}{dx} \cos ^2(h) + \frac{df}{dy} \sin (h) ,[/tex]
then
[tex]\left( \frac{dF}{dr}\right) ^2 =\left( \frac{df}{dx} \cos ^2(h) + \frac{df}{dy} \sin (h) \right) ^2 = \left( \frac{df}{dx}\right) ^2 \cos ^4(h) +2\frac{df}{dx}\cdot\frac{df}{dy} \cos ^2(h)\sin (h)+ \left( \frac{df}{dy}\right) ^2 \sin ^2(h) [/tex]
FAQ: Trig step in a chain rule question
What is the chain rule in trigonometry?
The chain rule in trigonometry is a formula used to find the derivative of a composition of functions. It is used when a function is composed of two or more functions, where one function is applied to the output of another.
How do you solve a trig step in a chain rule question?
To solve a trig step in a chain rule question, you first need to identify the inner and outer functions. Then, you can use the chain rule formula, which states that the derivative of the outer function multiplied by the derivative of the inner function. Finally, apply any trigonometric identities or rules to simplify the expression.
What are some common mistakes when using the chain rule in trigonometry?
Some common mistakes when using the chain rule in trigonometry include forgetting to apply the derivative to the outer function, not simplifying the expression using trigonometric identities, and mixing up the order of the inner and outer functions.
How can I practice solving trig step in a chain rule questions?
To practice solving trig step in a chain rule questions, you can find practice problems online or in a calculus textbook. It is also helpful to work through examples with a step-by-step solution to understand the process and identify any mistakes.
When is the chain rule used in real-world applications?
The chain rule is used in many real-world applications, including physics, engineering, economics, and biology. For example, it can be used to calculate the rate of change in a system or to optimize a process by finding the maximum or minimum value of a function.
9K
