Trig Substitution for Whitman 8.4.8: Complete the Square
In summary: I get it right. Whitman 8.4.8In summary, the table gives the following substitutions: $\cosh\theta \text{ or } \sinh\theta \text{ be used? } $. The table says to use $\cosh\theta \text{ or } \sinh\theta \text{ if } $ $x-1<\cosh(u)$ and $x+2\sqrt{x(x-2)}>\sinh(u)$.
karush
MHB
3,269
Whitman 8.4.8 Trig substitution?
Whitman 8.4.8
Complete the square..
\begin{align*}
\int\sqrt{x^{2}-2x}dx &=\int\sqrt{x^{2}-2x+1-1}dx\\
&=\int\sqrt{(x-1)^{2}-1^{2}}dx\\
&=\int\sqrt{U^{2}-1^{2}}dx\\
\end{align*}
Was wondering what substation best to use
Can $\cosh\theta \text{ or } \sinh\theta \text{ be used? } $
The table will give this but don't know how it was derived?
$$\int\sqrt{x^{2}-a^{2}}dx
=\frac{x}{2}\sqrt{x^{2}-a^{2}}
-\frac{a^{2}}{2}\log |x
+\sqrt{x^{2}-a^{2}}|+c.$$
So..
$$=\frac{x}{2}\sqrt{(x-1)^{2}-1}
-\frac{1}{2}\log |x
+\sqrt{(x-1)^{2}-1}|
+c.$$
A hyperbolic trig. identity we can use is:
\(\displaystyle \cosh^2(z)-\sinh^2(z)=1\)
How would you proceed from here? :)
Whitman 8.4.8
\begin{align*}
&=\int\sqrt{u^{2}-1^{2}}du\\
\end{align*}
$$ \sinh^2{x}=\cosh^2 {x}-1$$
$u=\cosh{x} \ \ \ du=\sinh{x} dx$
Then
$\displaystyle
\int\sqrt{\cosh^2 {u} -1^{2}}du
=\int \sinh^2 {u} \ du$
So..
-\frac{1}{2}\log |x
+c.$$
Okay, we are given:
\(\displaystyle I=\int \sqrt{x^2-2x}\,dx\)
And completing the square:
\(\displaystyle I=\int \sqrt{(x-1)^2-1}\,dx\)
Now, at this point you want to make the substitution:
\(\displaystyle x-1=\cosh(u)\,\therefore\,dx=\sinh(u)\,du\)
And we have:
\(\displaystyle I=\int \sqrt{\cosh^2(u)-1}\,\sinh(u)\,du=\int \sinh^2(u)\,du\)
Now you want to use the identity:
\(\displaystyle \cosh(2z)=2\sinh^2(z)+1\)
$$\displaystyle \frac{\cosh{2z}}{2}
-\frac{1}{2}
=\sinh^2{z}$$
So
$$\frac{1}{2}\int \cosh{2z}\
- \int \frac{1}{2} \ dx $$
Sorry lots of @#$ with WiFi here
-\frac{1}{2}
=\sinh^2{z}$$
So
Well, I would just write the next step as:
\(\displaystyle I=\frac{1}{2}\int \cosh(2u)-1\,du\)
Now, it is fairly simple to obtain the anti-derivative...then you go through the process of back-substituting for $u$.
$\displaystyle I=
\frac{1}{2}\int \cosh(2u)-1\,du=
\frac{e^{2u}\left(e^{4u}-4ue^{2u}-1\right)}{8}+C$
I was thinking more along the lines of:
\(\displaystyle I=\frac{1}{4}\sinh(2u)-\frac{1}{2}u+C\)
Next, use the identity:
\(\displaystyle \sinh(2z)=2\sinh(z)\cosh(z)\):
\(\displaystyle I=\frac{1}{2}\sinh(u)\cosh(u)-\frac{1}{2}u+C\)
Next, recall we used:
\(\displaystyle \cosh(u)=x-1\)
\(\displaystyle \sinh(u)=\sqrt{\cosh^2(u)-1}=\sqrt{(x-1)^2-1}\)
And let's also apply the inverse function as a log formula:
\(\displaystyle \arcosh(z)=\ln\left(z+\sqrt{z^2-1}\right)\)
To state:
\(\displaystyle I=\frac{1}{2}\left(\sqrt{(x-1)^2-1}\right)(x-1)-\frac{1}{2}\ln\left|x-1+\sqrt{(x-1)^2-1}\right|+C\)
Now, observing the first term, when expanded, contains a constant, we may write:
\(\displaystyle I=\frac{x}{2}\sqrt{x^2-2x}-\frac{1}{2}\ln\left|x-1+\sqrt{x(x-2)}\right|+C\)
Next, applying some log properties:
\(\displaystyle I=\frac{x}{2}\sqrt{x^2-2x}-\frac{1}{2}\ln\left|2(x-1)+2\sqrt{x(x-2)}\right|+C+\frac{1}{2}\ln(2)\)
\(\displaystyle I=\frac{x}{2}\sqrt{x^2-2x}-\frac{1}{2}\ln\left|x+2\sqrt{x(x-2)}+x-2\right|+C\)
\(\displaystyle I=\frac{x}{2}\sqrt{x^2-2x}-\frac{1}{2}\ln\left|\left(\sqrt{x}+\sqrt{x-2}\right)^2\right|+C\)
\(\displaystyle I=\frac{x}{2}\sqrt{x^2-2x}-\ln\left|\sqrt{x}+\sqrt{x-2}\right|+C\)
Wow. That was great help.
Frankly I would of derailed inspite of all the other examples I looked at
Just glad I'm getting all the great MHB help now
before hitting it all cold when
the Calc II class starts up in August 😊😊😊
I can see now how these substitutions work.
I'll keep trying more of these
FAQ: Trig Substitution for Whitman 8.4.8: Complete the Square
What is trig substitution?
Trig substitution is a method used to evaluate integrals that involve expressions with a quadratic (degree 2) term and a square root. It involves substituting a trigonometric function for the variable in the expression, which can make the integral easier to evaluate.
Why is trig substitution used in Whitman 8.4.8?
Trig substitution is used in Whitman 8.4.8 because the integral in this problem involves a quadratic term and a square root. By using trig substitution, the integral can be rewritten in terms of trigonometric functions, making it easier to evaluate.
How do I know which trigonometric function to substitute?
The trigonometric function to substitute depends on the expression in the integral. In Whitman 8.4.8, the expression has the form √(a^2 - x^2), so we use the substitution x = a sinθ. In general, the substitution can be determined by using the Pythagorean identity and matching it to the expression in the integral.
What do I do after substituting the trigonometric function?
After substituting the trigonometric function, you will need to rewrite the integral in terms of the new variable, θ. This may involve using trigonometric identities to simplify the expression. Then, you can evaluate the integral using standard techniques like integration by parts or u-substitution.
Are there any special cases to consider in trig substitution?
Yes, there are some special cases to consider in trig substitution. One common case is when the expression in the integral involves a quadratic term with a negative coefficient. In this case, you will need to use a different trigonometric substitution, such as x = a tanθ. It is important to carefully consider the form of the expression before choosing the appropriate trig substitution.
