Trig Substitution Homework: Int x^2 + 36/4x^2
In summary, the given problem involves using the substitution x = 6 tan theta to simplify the integral. However, the correct substitution should be x = 6 sin theta. Converting the secant and tangent functions to their sine and cosine equivalents can make the problem easier. The trig identity csc^2(theta) = cot^2(theta)+1 can also be useful in solving the problem.
mathor345
[tex]\int\frac{\sqrt{x^2 + 36}}{4x^2}}dx[/tex]
sqrt(a^2 + x^2) substitution for x = a tan theta
I set
x = 6 tan theta
x^2 = 36 tan^2 theta
dx = 6 sec^2 x
[tex]\int\frac{\sqrt{36 + 36 tan \theta}}{144 tan \theta}dx[/tex]
[tex]\int\frac{\sqrt{36(tan \theta + 1)}}{144 tan \theta}dx[/tex]
[tex]\int\frac{\sqrt{36(sec^2 \theta)}}{144 tan \theta}dx[/tex]
Then the numerator becomes 6 sec theta and then i multiply it by dx to get 36 sec^3 theta over 144 tan theta. Not sure where I went wrong. I've done other similar problems but they had the radical on bottom or the denominator was simply a variable.
Firstly, the bottom should be 144 tan^2(theta). Squared.
Next, there isn't a problem here. Some trig sub problems are harder than others. This is one of them. I recommend converting the secant and tangent functions to their sine and cosine equivalents. It might make it easier.
EDIT: After you do that, the trig identity [tex]csc^2(\theta) = cot^2(\theta)+1[/tex] will be a big help.
[itex] x= 6\sinh t [/itex] as a substitution immediately solves the problem.
FAQ: Trig Substitution Homework: Int x^2 + 36/4x^2
What is trig substitution?
Trig substitution is a method used to solve integrals that involve expressions containing square roots of quadratic functions or expressions containing the sum or difference of squares.
Why is trig substitution useful?
Trig substitution is useful because it allows us to simplify complicated integrals into simpler ones that we can easily solve using trigonometric identities.
How do you determine which trig substitution to use?
The trig substitution to use depends on the form of the integral. If the integral contains √(a^2-x^2), we use x = a sinθ. If it contains √(x^2-a^2), we use x = a secθ. If it contains √(x^2+a^2), we use x = a tanθ.
How do you solve a trig substitution integral?
After substituting the appropriate trigonometric expression for x, we use trigonometric identities to rewrite the integral in terms of θ. Then, we solve the integral using basic integration techniques like u-substitution or integration by parts. Finally, we substitute back in the original variable to get the final answer.
Can trig substitution be used for all integrals involving square roots?
No, trig substitution can only be used for integrals where the square root is under a quadratic function or the sum or difference of squares. For other types of square roots, different integration techniques like completing the square or using a trigonometric substitution may be necessary.
