Trig substitution (integration)
In summary, trig substitution is a technique used in integration to solve integrals involving radical functions or expressions with quadratic terms. It is most useful when the integral involves a radical function or quadratic term. The three major trig substitutions used are √(a^2-x^2), √(a^2+x^2), and √(x^2-a^2). The trig substitution to use depends on the form of the integral and it is important to check for other algebraic manipulations before using it. Some common mistakes to avoid when using trig substitution include not substituting back for the original variable, using incorrect trig identities, forgetting absolute values, and not checking for other simplifications.
joess
I'm not asking for someone to do the question for me but I was just wondering what I'm supposed to sub in. Do I put in
as if it was (x^2-9)^(1/2) or do I have to do something differently if there is a constant in front of the x^2? Thanks for any help.
You are correct, secant is the correct trig function to use in this case.
However the coefficient is incomplete, you need to divide out the 4 as well.
So is it x=(3/2)sec(theta) ?
That's right! :)
FAQ: Trig substitution (integration)
What is trig substitution in integration?
Trig substitution is a technique used in integration to solve integrals involving radical functions or expressions with quadratic terms. It involves replacing these expressions with equivalent trigonometric functions in order to simplify the integral.
When should I use trig substitution?
Trig substitution is most useful when the integral involves a radical function such as √(a^2-x^2) or √(a^2+x^2). It can also be used when the integrand contains a quadratic term in the form of a^2-x^2 or a^2+x^2.
What are the three major trig substitutions?
The three major trig substitutions used in integration are:
  • √(a^2-x^2) → x = a sinθ, dx = a cosθ dθ
  • √(a^2+x^2) → x = a tanθ, dx = a sec^2θ dθ
  • √(x^2-a^2) → x = a secθ, dx = a secθ tanθ dθ
How do I know which trig substitution to use?
The trig substitution to use depends on the form of the integral. If the integrand contains a^2-x^2, then use the first substitution. If it contains a^2+x^2, use the second substitution. If it contains x^2-a^2, use the third substitution. It is also important to check if any other algebraic manipulations can be done to simplify the integral before using trig substitution.
What are the common mistakes to avoid when using trig substitution?
Some common mistakes to avoid when using trig substitution include:
  • Forgetting to substitute back for the original variable after integrating
  • Not using the correct trig identity when simplifying the integral
  • Forgetting to include the absolute value when dealing with radical functions
  • Not checking for other algebraic manipulations that can be done to simplify the integral
