Trig ((tanx - sinx)/sin^3x) = (1/(cosx - cos^2x))
  • Thread starter Attis
  • Tags
    Trig
In summary, the homework statement is trying to find a solution to a equation that states that (tanx - sinx)/sin^3x = (1/(cosx - cos^2x))
Attis
50
show that ((tanx - sinx)/sin^3x) = (1/(cosx - cos^2x))
sin^2 = 1-cos^2v
cos^2 = 1-sin^2v
On the left hand side: I plugged in sinx/cosx for tanx. I then divided both the numerator and denominator by sinx to get ((1/cosx - 1)/ sin^2x).
After this point I got stuck. I tried plugging in 1-cos^2x for sin^2x and simplifying the fraction, but it didn´t work. Do you guys have any tips on how to progress?
are you sure the righthand side is 1/(cosx - cos^2x). I am thinking it should be 1/(cosx + cos^2).
I started by assuming its true and then doing the crossproduct trick ie a/b = c/d ==> ad = bc and then used algebra to reduce it down and from there you can see how to derive it.
Likes 1 person
Both of you are writing nonsense! "cos^2" or "sin^2" without an angle argument such as "x" is absolutely meaningless. (Both in jedishrfu's answer and in attis's "relevant equations".
Apparently what's meant is
[tan(x) - sin(x)]/sin3(x) = 1/[cos(x) - cos2(x)]
If you divide a factor of sin(x) out of both the numerator and the denominator on the left, you have
[sec(x) - 1] / sin2(x) = 1/[cos(x) - cos2(x)]
If you then multiply both sides by cos(x) sin2(x), you have
1 - cos(x) = sin2(x) / [1 - cos(x)]
And now I see jedishrfu's point, that this is not going to come out to an identity unless the two remaining binomials include one sum and one difference.
BTW, shouldn't a trig question be in "precalculus" homework?
Thanks for pointing out my mistake. I think in both of our cases it was a simple typo to leave out the x argument and not nonsense. Please be kind when you respond and try to understand the intent of the poster. Sometimes autocorrect will interfere with your typing and cause these kinds of errors (but not in this case i simply missed typing the x).
Also, we try to help here without giving away too much of the answer until we see some effort on a part of the original poster. It took me awhile to see the wisdom of this approach.
jedishrfu said:
are you sure the righthand side is 1/(cosx - cos^2x). I am thinking it should be 1/(cosx + cos^2x).
You were right about my typo. It should´ve been 1/(cosx + cos^2x). Sorry! I used the crossproduct trick and algebra... and it worked! Super. I don´t know why the other guy is calling it nonsense.
Thanks! Have a nice weekend.
Related to Trig ((tanx - sinx)/sin^3x) = (1/(cosx - cos^2x))
1. What is the purpose of this trigonometric equation?
The purpose of this equation is to calculate the value of x, given the expression (tanx - sinx)/sin^3x on the left side and (1/(cosx - cos^2x)) on the right side.
2. How do you solve this trigonometric equation?
To solve this equation, you can use algebraic manipulation to simplify both sides of the equation and then use trigonometric identities to further simplify the expression. Finally, you can solve for x by isolating it on one side of the equation.
3. Are there any restrictions on the values of x in this equation?
Yes, there are restrictions on the values of x in this equation. Since the expression involves both tangent and cosine functions, x cannot be equal to any value that would make the denominator of these functions equal to zero. Therefore, x cannot be equal to 0, π/2, 3π/2, etc.
4. Can this equation be used to solve real-world problems?
Yes, this equation can be used to solve real-world problems that involve trigonometric functions, such as calculating angles and distances in geometry or physics problems.
5. Are there alternative ways to express this trigonometric equation?
Yes, there are alternative ways to express this equation. For example, you can use the reciprocal identities to rewrite the equation as (cotx - cscx)/(1 - cosx) = (1/cosx). You can also use the Pythagorean identities to simplify the equation further.
