Trigonometric graph transformation
In summary, the steps to transform the given equation are: 1. Stretch vertically by a factor 9 to get 9x^2sin(3x) 2. Stretch horizontally by a factor 3 to get 9x^2sin(x) 3. Shift to the left by 1 unit, resulting in the equation y = 9x^2sin(x+1). However, this answer is incorrect and the correct equation should be y = 9(x^2+2x+1)sin(x+1). The mistake was made in step 2, where the equation should have been stretched horizontally by dividing x by 3, not 3x. Additionally, the last step of simplifying
ArjenB
Transform the following equation:
X2sin(3x)
3. Shift to the left by a value of 1.2. The attempt at a solution
1. Stretching vertically by a factor 9 gives:
9x2sin(3x)
2. Stretching vertically by factor 3 is done by dividing 3x by 3, so I get
9x2sin(x)3. Shifting one to the left gives (I think I am going wrong here):
9(x+1)2sin(x+1)
Which can be simplified into:
(9x2+18x+9)sin(x+1)But this answer is wrong. Where did I go wrong?
X2sin(3x)
9x2sin(3x)
9(x+1)2sin(x+1)
You do not have an equation; an equation has an "=" sign in it, and your expression does not. What you have is a function of x.
I think the problem should be restated as follows. For the graph ##y = x^2 \sin 3x##:
1. Stretch the graph vertically by a factor of 9.
2. Stretch the graph horizontally by a factor of 3.
3. Shift the graph to the left by 1 unit.
Your solution of 1 is correct: the stretched graph is ##y = 9 x^2 \sin 3x.##
For 2: think about it: a point such as ##(k,y(k))## moves to ##(3k,y(k))## in the stretched graph, so if the old graph is ##y = f(x)## and the new graph is ##y = F(x)##, you can see how ##F(x)## must be related to the function ##f(x)##. You have it partly right, but not completely right.
For 3: a point ##(k,f(k)## in the old graph moves to ##(k-1, f(k)## in the new graph. From that, you can get the equation ##y = F(x)## of the new graph in terms of the old graph ##y = f(x).##
X2sin(3x)
I agree complete with what Ray already said: you do not have an equation here.
9x2sin(3x)
You should have an equation here. Specifically, ##y = 9x^2 \sin(3x)##.
9x2sin(x)
Again, this should be an equation. Also, you wrote "stretching vertically by a factor 3" -- the stretch is supposed to be horizontally by a factor of 3. You need to be working with ##y=x^2\sin(3x)##
9(x+1)2sin(x+1)
Should be an equation. Start with ##y = x^2\sin(3x)##, and shift it to the left by 1 unit.
(9x2+18x+9)sin(x+1)
Aside from being incorrect, you didn't really simplify it by expanding ##(x + 1)^2##.
FAQ: Trigonometric graph transformation
1. What is a trigonometric graph transformation?
A trigonometric graph transformation is a change in the shape or position of a trigonometric function, such as sine, cosine, or tangent, on a coordinate plane. This can be achieved by altering the equation of the function, which will result in a change in its graph.
2. What are the most common types of trigonometric graph transformations?
The most common types of trigonometric graph transformations are translations, reflections, and dilations. Translations involve shifting the graph horizontally or vertically. Reflections involve flipping the graph across a line of reflection. Dilations involve stretching or compressing the graph.
3. How do you graph a trigonometric function after a transformation?
To graph a trigonometric function after a transformation, you will need to apply the transformation to the original function and plot the new points on the coordinate plane. This can be done by using a table of values or by using the properties of the specific transformation.
4. What is the purpose of trigonometric graph transformations?
The purpose of trigonometric graph transformations is to allow us to visualize how changes in the equation of a trigonometric function affect its graph. This can help us understand the behavior and properties of the function, and also allow us to make predictions about its values at different points.
5. Can trigonometric graph transformations be used in real-world applications?
Yes, trigonometric graph transformations have many real-world applications. For example, they can be used to model and analyze periodic phenomena such as sound waves, ocean tides, and electromagnetic waves. They are also used in engineering and construction to design and build structures with specific angles and dimensions.
