MHB Trigonometric inequality with pi
The discussion revolves around solving the trigonometric inequality $$ \sin{(\pi x)}>\cos{(\pi \sqrt{x})} $$ and explores various approaches to simplify it. Initial attempts to manipulate the inequality using sine and cosine properties were met with challenges, particularly due to the presence of the square root. The conversation shifts to analyzing the inequality under different quadrant assumptions, leading to specific ranges for x, such as $$ 0 \leq x \leq \frac{1}{4} $$ and $$ \frac{1}{2} \leq x \leq 1 $$. The periodicity of the sine function is also raised as a concern, suggesting that the solutions may not be exhaustive without considering additional periodic terms. Overall, the discussion highlights the complexity of the inequality and the need for careful quadrant analysis.
karseme
I don't know how to solve this. I would really appreciate some help.
I tried to do something, but didn't get anything.
If I move cos to the left side, I can't apply formulas for sum. Since arguments of sin and cos have $$ \pi $$, I think there is no way I can somehow make it simpler by using addition formulas. If I could somehow get rid of that square root, but how?! I know that $$ x=(\sqrt{x})^2 $$, but what's use of that when I don't see how to get rid of that power of 2. I tried squaring everything and doing something, but I didn't get anything from that. I don't know how to proceed. I don't see there are any formulas which I could use to make this simpler.
Must solve this somehow, would appreciate your help.
Mathematics news on Phys.org
Hi karseme! ;)
Suppose we assume that both angles are in the first quadrant.
That is, $0\le \pi x \le \frac\pi 2$ and $0\le \pi \sqrt x \le \frac\pi 2$.
So $0\le x \le \frac 14$.
Then:
$$\sin{(\pi x)}>\sin{(\frac\pi 2 - \pi \sqrt{x})}$$
Since the sine is increasing in the first quadrant, we get:
$$\pi x>\frac\pi 2 - \pi \sqrt{x}$$
It follows that:
$$\sqrt x > \frac 12 (\sqrt 3 - 1)$$
And since $\sqrt{}$ is increasing, we find:
$$\frac 12 (2-\sqrt 3) < x \le \frac 14$$
We can continue with considering cases if the angles are in other quadrants.
Thank you very much. :) It was very helpful.
So, if we assume that both angles are in the second quadrant, then the following must be true:
$$ \dfrac{\pi}{2} \leq \pi x \leq \pi \qquad \land \qquad \dfrac{\pi}{2} \leq \pi \sqrt{x} \leq \pi \, \implies \dfrac{1}{2} \leq x \leq 1 $$
Since $$ \pi \sqrt{x} $$ is in the second quadrant we have:
$$ cos{(\pi \sqrt{x})}=-\cos{(\pi-\pi \sqrt{x})}=-\sin{(\dfrac{\pi}{2} + \pi - \pi \sqrt{x})}=-\sin{(\dfrac{3\pi}{2}- \pi \sqrt{x})}=\sin{(\pi \sqrt{x}-\dfrac{3\pi}{2})} $$
So,
$$ \sin{(\pi x)} > \sin{(\pi \sqrt{x}-\dfrac{3\pi}{2})} $$
Since sine is decreasing in the second quadrant then we have:
$$ \pi x < \pi \sqrt{x}-\dfrac{3\pi}{2} $$
This quadratic inequality does not have solution(for t=\sqrt{x}).
Is this good? But, when I solve the given inequality for $$ \dfrac{1}{2} \leq x \leq 1 $$ it is true.
So, those are the solutions...is it any good?
But what about periodicity of sine? then those can't be the only solutions?
So,
I'm afraid we have to consider $\pi x$ to be in any quadrant and $\pi\sqrt x$ to be in the same or any other quadrant.
Furthermore, we have to consider that they may have an additional $2k\pi$ added to them that can be different for each of them. (Sweating)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
