Trigonometric inequation with tangent function
In summary: Remember to always be thorough and precise in your solutions. In summary, your attempt at a solution of this task has some flaws and is not complete. You should consider all possible cases and be thorough in your approach before presenting a solution.
karseme
I just want your opinion on my attempt at a solution of this task:
\(\displaystyle \tan{\dfrac{x}{2}}>\dfrac{\tan{x}-2}{\tan{x}-2}\)
My attempt:
We know that:
\(\displaystyle \tan{x}=\dfrac{2\tan{\dfrac{x}{2}}}{1-\tan^2{\dfrac{x}{2}}} \)
But, at the beginning we should set limits to tangent function:
\(\displaystyle \dfrac{x}{2} \neq \dfrac{\pi}{2}+k\pi, k\in\mathbb{Z} \qquad x \neq \dfrac{\pi}{2}+k\pi, k\in\mathbb{Z} \\
x \neq \pi + 2k\pi,k\in\mathbb{Z} \qquad x \neq \dfrac{\pi}{2}+k\pi, k\in\mathbb{Z} \)
If we use the identity that I've given above, we get:
\(\displaystyle \tan{\dfrac{x}{2}} > \dfrac{2\tan^2{\dfrac{x}{2}}+2\tan{\dfrac{x}{2}}-2}{2+2\tan{\dfrac{x}{2}}-2\tan^2{\dfrac{x}{2}}} \)
Now we can have two cases: denominator is less than zero and denominator is larger than zero.
Let's use substitution \(\displaystyle \tan{\dfrac{x}{2}}=m \) for the convenience, then we have quadratic equation:
\(\displaystyle -2m^2+2m+2=0 \), with the solutions \(\displaystyle m_{1,2}=\dfrac{1 \pm \sqrt{5}}{2} \).
Now, denominator is larger than 0 for \(\displaystyle m \in \langle \dfrac{1 - \sqrt{5}}{2},\dfrac{1 + \sqrt{5}}{2} \rangle \implies \tan{\dfrac{x}{2}}\in\langle \dfrac{1 - \sqrt{5}}{2},\dfrac{1 + \sqrt{5}}{2} \rangle \).
Now we can multiply inequality with denominator because denominator is not 0 for those values and it is positive so inequality sign won't "change", we have:
\(\displaystyle \tan{\dfrac{x}{2}}(2+2\tan{\dfrac{x}{2}}-2\tan^2{\dfrac{x}{2}}) > 2\tan^2{\dfrac{x}{2}}+2\tan{\dfrac{x}{2}}-2 \)
We have:
\(\displaystyle \tan^3{\dfrac{x}{2}} < 1 \implies \tan{\dfrac{x}{2}} < 1 \)
Then,
\(\displaystyle \tan{\dfrac{x}{2}} \in \langle \dfrac{1 - \sqrt{5}}{2},1 \rangle \\ \dfrac{x}{2} \in \langle \arctan{\dfrac{1 - \sqrt{5}}{2}}+k\pi, \dfrac{\pi}{4}+k\pi \rangle ,k\in\mathbb{Z} \\ x \in \langle 2\arctan{\dfrac{1 - \sqrt{5}}{2}}+2k\pi, \dfrac{\pi}{2}+2k\pi \rangle ,k\in\mathbb{Z} \)
Which is a good solution because it does not contain our limits for tangent function.
Now for the second case, we assume that: \(\displaystyle m \in \langle -\infty,\dfrac{1 - \sqrt{5}}{2} \rangle \cup \langle \dfrac{1 + \sqrt{5}}{2}, +\infty \rangle \implies \tan{\dfrac{x}{2}}\in \langle -\infty,\dfrac{1 - \sqrt{5}}{2} \rangle \cup \langle \dfrac{1 + \sqrt{5}}{2}, +\infty \rangle\)
Now we can multiply the inequality with the denominator but the ">" sign will "change":
\(\displaystyle \tan{\dfrac{x}{2}}(2+2\tan{\dfrac{x}{2}}-2\tan^2{\dfrac{x}{2}}) < 2\tan^2{\dfrac{x}{2}}+2\tan{\dfrac{x}{2}}-2 \)
We have:
\(\displaystyle \tan^3{\dfrac{x}{2}} > 1 \implies \tan{\dfrac{x}{2}} > 1 \)
Then,
\(\displaystyle \tan{\dfrac{x}{2}} \in \langle \dfrac{1 + \sqrt{5}}{2}, +\infty \rangle \\ \dfrac{x}{2} \in \langle \arctan{\dfrac{1 + \sqrt{5}}{2}}+k\pi, \dfrac{\pi}{2}+k\pi \rangle ,k\in\mathbb{Z} \\ x \in \langle 2\arctan{\dfrac{1 + \sqrt{5}}{2}}+2k\pi, \pi+2k\pi \rangle ,k\in\mathbb{Z} \)
And finally the solution is:
\(\displaystyle x \in \langle 2\arctan{\dfrac{1 - \sqrt{5}}{2}}+2k\pi, \dfrac{\pi}{2}+2k\pi \rangle \cup \langle 2\arctan{\dfrac{1 + \sqrt{5}}{2}}+2k\pi, \pi+2k\pi \rangle ,k\in\mathbb{Z} \)
Is this a good solution or? If not please help me solve this task. Appreciate your help.
Mathematics news on Phys.org
I appreciate the effort you put into finding a solution for this task. However, I have some concerns about your approach.
Firstly, it is not necessary to set limits for the tangent function at the beginning. The inequality \tan{\dfrac{x}{2}} > \dfrac{\tan{x}-2}{\tan{x}-2} is already defined for all values of x except when \tan{x} = 2. So, your limits are not relevant to the problem at hand.
Secondly, your solution only considers the case when the denominator is positive. You should also consider the case when the denominator is negative. In this case, the inequality sign should be reversed, and your solution will be different.
Lastly, your final solution is not complete. You have not considered the case when \tan{x} = 2. In this case, the inequality is not defined, and your solution does not cover this scenario.
In conclusion, your attempt at a solution has some flaws and is not complete. I suggest double-checking your approach and considering all possible cases before presenting a solution. Keep up the good work and continue to improve your problem-solving skills.
FAQ: Trigonometric inequation with tangent function
What is a trigonometric inequation with tangent function?
A trigonometric inequation with tangent function is a mathematical statement that involves an inequality with a tangent function. It is used to solve for values of an angle or variable that satisfy the inequality.
How do you solve a trigonometric inequation with tangent function?
To solve a trigonometric inequation with tangent function, you must first isolate the tangent function by using algebraic manipulation. Then, use the inverse tangent function to find the possible values of the angle or variable. Finally, check your solutions by plugging them back into the original inequality.
What are the common mistakes when solving trigonometric inequations with tangent function?
Some common mistakes when solving trigonometric inequations with tangent function include forgetting to check for extraneous solutions, not using parentheses correctly when simplifying, and not accounting for the different possible quadrants when using inverse tangent function.
Can a trigonometric inequation with tangent function have multiple solutions?
Yes, a trigonometric inequation with tangent function can have multiple solutions. This is because the tangent function is periodic and has multiple values for a given angle. It is important to check all possible solutions when solving these types of equations.
How do you graph a trigonometric inequation with tangent function?
To graph a trigonometric inequation with tangent function, first solve for the variable or angle using the steps mentioned above. Then, plot the solutions on a coordinate plane and shade the appropriate regions based on the inequality symbol. The resulting graph will show the values that satisfy the inequation.
