Trigonometric Integral Confusion
In summary, the student is having difficulty with integrating \int \left(1-x^2\right)^{-1/2}dx and \int \left(1+x^2\right)^{-1/2}dx. They are also having difficulty with sec(arctan(x)). The student finds the answer using the hyperbolic functions and differentiation.
Char. Limit
So, for absolutely no good reason I decided to practice trigonometric substitution. I started with [itex]\int \left(1-x^2\right)^{-1/2} dx[/itex], and that was easy, everything canceled out nicely. Then I tried [itex]\int \left(1+x^2\right)^{-1/2} dx[/itex], and although the integral was fine, everything did not cancel out nicely afterward. So I need help on one minor issue.
[tex] sec(u) = \frac{sec^2(u) + sec(u) tan(u)}{sec(u) + tan(u)}[/tex]
[tex]\int \frac{dx}{\sqrt{1+x^2}}[/tex]
[tex]\int \frac{sec^2(u) du}{\sqrt{1+tan^2(u)}}[/tex]
[tex]\int sec(u) du[/tex]
[tex]\int \frac{sec^2(u) + sec(u) tan(u)}{sec(u) + tan(u)} du[/tex]
[tex]\int \frac{dv}{v}[/tex]
[tex]ln(v)[/tex]
[tex]ln(tan(u) + sec(u))[/tex]
[tex]ln(x + sec(tan^{-1}(x)))[/tex]
Now, is there any way to simplify sec(arctan(x))?
Let θ = arctan(x), then tan(θ) = x = x/1. Draw a right triangle, label the sides, and then find sec(θ).
Draw a right triangle where the leg opposite θ is length x and the adjacent leg is length 1 so that tan θ=x/1.
Hmm... I did that, but I don't think my answer is right... the O=x, A=1, H=sqrt(1+x^2) idea gives me sec(arctan(x))=sqrt(1+x^2), and that just doesn't sound right... but it probably is.
So...
[tex]ln\left(x+\sqrt{1+x^2}\right) +C[/tex]
Is the answer? For some reason I expected a trig function to pop up like it did with 1/sqrt(1-x^2)...
That's the right answer, you can always check on Wolfram|Alpha too.
Or you could differentiate your answer and see if you get the integrand back.
If you think in terms of the hyperbolic trig functions, your answer is arcsinh(x), so a trig function does actually pop up.
Oh I see. Thanks for the info on the arsinh(x) function... I just looked it up on Wikipedia, and it helped me understand that there was a trig function hidden in that logarithmic function.
There are two ways to solve this integral. There is the use of [tex]x=\tan\theta[/tex] and by the use of the identity [tex]1+\tan^{2}theta =\sec^{2}\theta[/tex] and the use of [tex]x=\sinh u[/tex] and use [tex]\cosh^{2}u=1+\sinh^{2}u[/tex]. I personally think it is easier with the hyperbolic function.
Yes, but I had never heard of the hyperbolic functions before today, so I don't quite know the derivative of sinh and cosh. Is it the same as the derivative of sin and cos? Namely...
[tex]\frac{d sinh(x)}{dx} = cosh(x)[/tex]
[tex]\frac{d cosh(x)}{dx} = - sinh(x)[/tex]
Are those correct?
No. The definitions are as follows:
[tex]
\sinh x=\frac{e^{x}-e^{-x}}{2}\quad\cosh x=\frac{e^{x}+e^{-x}}{2}
[/tex]
From these definitions, you can calculate the derivatives and also prove the basic identity:
[tex]
\cosh^{2}x-\sinh^{2}x=1
[/tex]
From these three definitions, you can pretty much prove everything you need.
Mat
Oh, I see. So the derivative is a two-point cycle, not a four-point cycle. Thank you.
There's not much to learn about hyperbolic functions apart from their definitions, their graphs and their derivatives. I am not sure of their geometric interpretation, there must be one, hyperbolic geometry perhaps?
mat
I just looked it up, they are supposed to give measures of a hyperbola, I believe. Somehow.
FAQ: Trigonometric Integral Confusion
What is Trigonometric Integral Confusion?
Trigonometric Integral Confusion is a mathematical concept that refers to the difficulty in integrating functions that involve trigonometric functions, such as sine, cosine, and tangent.
Why is Trigonometric Integral Confusion important?
Trigonometric Integral Confusion is important because it is a common problem encountered in many areas of mathematics and science, and understanding how to solve these integrals is crucial for solving complex problems.
What are some strategies for solving Trigonometric Integral Confusion?
Some strategies for solving Trigonometric Integral Confusion include using trigonometric identities, substitution, and integration by parts.
Can Trigonometric Integral Confusion be avoided?
Trigonometric Integral Confusion cannot be completely avoided, but with practice and understanding of the concepts, it can be minimized.
How can I improve my skills in solving Trigonometric Integral Confusion?
Improving skills in solving Trigonometric Integral Confusion can be achieved through practice, studying various methods and techniques, and seeking help from teachers or tutors if needed.
