mcastillo356
- 358
- TL;DR
- There are some steps I haven't got a clue, and some others I should have, but ain't.
Hi, PF
First I will quote it; next the doubts and my attempt:
"In mathematics, trigonometric substitution is the replacement of trigonometric functions for other expresions. In calculus, trigonometric substitution is a technique for evaluating integrals. (...)
Case I: Integrands containing ##a^2-x^2##
Let ##x=a\sin\theta##, and use the identity ##1-\sin^2\theta=\cos^2\theta##
Example 1
In the integral
##\displaystyle\int{\displaystyle\frac{dx}{\sqrt{a^2-x^2}}}##
we may use
##x=a\sin\theta,\quad{dx=a\cos\theta\,d\theta,\quad{\theta=\arcsin{\displaystyle\frac{x}{a}}}}##
Then,
##\displaystyle\int{\displaystyle\frac{dx}{\sqrt{a^2-x^2}}}=\displaystyle\int{\displaystyle\frac{a\cos\theta\,d\theta}{\sqrt{a^2-a^2\sin^2\theta}}}##
##\qquad{=\displaystyle\int{\displaystyle\frac{a\cos\theta\,d\theta}{\sqrt{a^2(1-\sin^2\theta)}}}}##
##\qquad{=\displaystyle\frac{a\cos\theta\,d\theta}{\displaystyle\sqrt{a^2\cos^2\theta}}}##
##\qquad{=\displaystyle\int{d\theta}}##
##\qquad{=\theta+C}##
##\qquad{=\arcsin{\displaystyle\frac{x}{a}}+C}##
The above step requires that ##a>0## and ##\cos\theta>0##. We can choose a to be the principal root of ##a^2##, and impose the restriction ##-\pi/2<\theta\<\pi/2## by using the inverse sine function." (Source: Wikipedia, "Trigonometric substitution".)
Doubts:
(i)- ##dx=a\cos\theta\,d\theta##: how is it derived?; any relationship with the Chain Rule?.
(ii)- It is required ##a>0## and ##\cos\theta>0##; every nonnegative real number has a unique nonnegative square root, called the principal square root or simply the square root. Am I right?:
(iii)- ##-1\leq x\leq 1## and ##-\pi/2\leq y\leq## are the domain and the range of ##y=\arcsin{(x)}##. I've plotted it, etc; should I explore ##x=\arcsin{(y)}##? It's clear that ##y=\cos{(x)}## is positive at the first and fourth quadrants.
Well, as you can see, I've put together doubts and attempt.
Greetings!
Example 1
In the integral
we may use
Then,
Doubts:
Greetings!
