Trigonometry- addition and factor forumla
In summary, the problem is to find the values of tan2A and tan2B given the equations tan(A+B)=3 and tan(A-B)=2. By using the identity \tan(x+y)=\frac{\tan(x)+\tan(y)}{1-\tan(x)\tan(y)}, the equations can be simplified to \displaystyle 3=\frac{x+y}{1-xy} and \displaystyle 2=\frac{x-y}{1+xy}, where x=tan(A) and y=tan(B). These are two equations with two unknowns, which can be solved by manipulating the expressions to eliminate a term and then finding the values for x and y. The values for tan2A and tan2B may
xiphoid
57
If tan(A+B) = 3 and tan(A-B) = 2, find tan2A and tan2B
tan (A - B) = (tan A - tan B)/(1 + (tan A)(tan B) and similar sort of one for tan(A+B)
i did some calculation and got tanA= (1-2tanB)/5tanB
after which there seems some thing missing for the proceeding calculations...
wonder what to do next?
For better service, try posting your math questions in either the Precalculus math or the Calculus sections of the HW forums.
Topic moved. As SteamKing wrote - this is definitely not "OtherSciences", but Math itself.
The "other identity" of "the sort" you are talking about is given like this:
[tex]\tan(x+y)=\frac{\sin(x+y)}{\cos(x+y)}=\frac{\sin(x)\cos(y)+\cos(x)\sin(y)}{\cos(x)\cos(y)-\sin(x)\sin(y)}=\frac{\tan(x)+\tan(y)}{1-\tan(x)\tan(y)}[/tex]
Now, a good start to this question would be to write everything you already have down: (name tan(a)=x and tan(b)=y) [itex]\displaystyle 3=\frac{x+y}{1-xy}[/itex] and [itex]\displaystyle 2=\frac{x-y}{1+xy}[/itex]. Then, these are two equations with two unknowns (a and b.) Try to manipulate the expressions and eliminate a term that you would not want in an equation with two unknowns. The rest follows relatively easily.
If you found some value for tan A whose inverse tangent is not very pleasant, you are doing something wrong; the value A comes out very nicely.
Tip: Your expression for tan A is not the simplest one possible. Try to find linear expressions.
Tip-2: There isn't only one solution.
FAQ: Trigonometry- addition and factor forumla
1. What is the addition formula for trigonometry?
The addition formula for trigonometry is sin(x+y) = sin(x)cos(y) + cos(x)sin(y) and cos(x+y) = cos(x)cos(y) - sin(x)sin(y).
2. How do you use the addition formula to solve trigonometric equations?
To solve trigonometric equations using the addition formula, you first need to rewrite the equation in terms of sin(x), cos(x), and/or tan(x). Then, use the addition formula to simplify the equation and solve for the unknown variable.
3. What is the factor formula for trigonometry?
The factor formula for trigonometry is sin(x)sin(y) = 1/2[cos(x-y) - cos(x+y)] and cos(x)cos(y) = 1/2[cos(x-y) + cos(x+y)].
4. How do you use the factor formula to simplify trigonometric expressions?
To simplify trigonometric expressions using the factor formula, you can use the identities sin^2(x) + cos^2(x) = 1 and tan(x) = sin(x)/cos(x). You can also substitute known values for the variables and then use the factor formula to simplify further.
5. Can the addition and factor formulas be used for all trigonometric functions?
Yes, the addition and factor formulas can be used for all trigonometric functions, including sin(x), cos(x), tan(x), sec(x), csc(x), and cot(x). However, it is important to note that the formulas may need to be modified for certain functions, such as sec(x) and csc(x).
