MHB Trigonometry and periodic functions
The Singapore Flyer completes a rotation every 32 minutes, starting from the 6 o'clock position. After 24 minutes, the person riding the wheel reaches the 3 o'clock position. At this point, the height of the person above the ground is calculated to be 90 meters, considering the total height of the Flyer is 165 meters. The calculations confirm that after 24 minutes, the person is at a height of 75 meters on the wheel itself. This discussion highlights the relationship between time, position, and height in trigonometric terms.
mak23
!HELP!
The Singapore Flyer, until recently the world's largest Ferris wheel, completes one rotation every 32 minutes.1 Measuring 150 m in diameter, the Flyer is set atop a terminal building, with a total height of 165 m from the ground to the top of the wheel. When viewed from Marina Centre, it turns in the clockwise direction. State the o'clock position on the wheel and height above the ground of a person who has ridden the wheel for 24 minutes. Assume that the person boarded the wheel at the 6 o'clock position.i don't know how to do this problem.please help!and thanks in advance.
Mathematics news on Phys.org
mak23 said:
!HELP!
Hi mak23! Welcome to MHB! ;)
Let's see... it starts at the bottom position (6 o'clock), and makes a full turn in 32 minutes.
That means it's at the top after 16 minutes isn't it?
And that's at 165 m from the ground.
How high would it be anyway at the starting position?
We should be able to tell, shouldn't we? Since it's given that the wheel is 150 m in diameter.
It also means that after 8 minutes, it's at a quarter of its turn.
And at 24 minutes, it's at three quarters of its turn, which is what the problem is about.
Can we tell how high that would be?
Thank you for the help!
I understand now.
so after 24 minutes the person should be at the 3'o clock position. And the person would be at a height of 75 m.
ahaa... since its on a building of 165 m, the person would be 165-75=90 m.Right?
Yep. (Nod)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
